Hey everyone,
last time i was at eastern creek i was told that the helmet i have is longer up to aussie standard and was told before i go back next time ill need a new one
now what i wana know is where in the wollongong/ sydney area is the best/ cheapest place to get motor sport helmets from?
https://www.sau.com.au/forums/topic/350304-helmets/
http://bikegearwarehouse8-px.rtrk.com.au/mx-gear/Mens_Motorcross_Helmets
or goto your local bike shop...they always have specials
eg today i got my carbon/kevlar MX helmet for 150bucks
basic open face helmets can be had for 80bucks but they are heavy and..... well shit to be honest
https://www.sau.com.au/forums/topic/350304-helmets/#findComment-5624891
Hey everyone,
Does it have as AS sticker on it? What brand/model and how old?
https://www.sau.com.au/forums/topic/350304-helmets/#findComment-5624919
+1, what standard is it that was knocked back?
CAMS helmet requirements are here: http://www.camsmanua...dule_G_Q111.pdf
importantly, it includes the following:
4.8 Moratoriums
(a) There is a moratorium on the implementation of any changes to apparel requirements, save for any identified and pressing safety related requirements which may arise or become evident, for non-international events, until 31 December 2012.
https://www.sau.com.au/forums/topic/350304-helmets/#findComment-5625306
It's been like that for ages and It's all pretty clear on their website:
Helmet Standards approved for Race for Real Off-Street Meetings
Drivers Drivers of vehicles slower than 10.99-seconds (1/4 mile) are permitted to use any helmet (full-face or open- face) meeting one of the following Standards:
• SNELL SA2000, SA2005, SFI 31.2A (USA)
• SNELL M2000, M2005, SFI 41.2A (USA)
• BS 6658-1985
• AS/NZS 1698:2006 or AS/NZS 1698.
https://www.sau.com.au/forums/topic/350304-helmets/#findComment-5625690
yeh i never knew that when i went up last time coz before that i had never had a problem and helmet is still in basically new condition.
but anyway im going to make a trip up to the place in auburn in the next week or so
https://www.sau.com.au/forums/topic/350304-helmets/#findComment-5625943
  • 3 months later...
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
