Hi All, I have just measured the ride height on my 33GTR and found it to be 355mm front and 350 rear centre of wheel to guard,only my back tyres wear out prematurely on the insides,can someone tell me if I only need a standard camber kit as I read in this thread, and what is mean't by standard, is the adjustment already there or only after you fit the kit?? how much are they new,and would you bother buying secondhand?? what brand kit should I look for ?? are they hard and or expensive to fit and can any wheel alignment outfit do it,??I have Tein suspension all round.Thanks GREYPEARL
https://www.sau.com.au/forums/topic/350306-gtr33-needs-rear-camber-adjustment/
At that height I believe you need a camber kit if its the same as on gtst, I would get both front and back, just get the whiteline adjustable camber bushes for front and back, and yes any reputable suspension place can install them alternatively its quite easy to remove the arms and take them to a workshop for them press out the old bushes and press in the new ones, 10T press required... then you can just bolt the arms back in and go get an alignment...
$150 approx for each kit I can remember exactly, check forums for people selling new kits or even ebay they come up sometimes... buy new though, you'll need one for back one for front, and they are different part numbers....
all of this info is pretty easy to find on the forums been done a heap of times...
Thanks for the reply mate,shame you are on the Gold Coast and I am in Victoria,I really think I only need to get the back done as it is noticeable there but I like the handling and don't want to upset the front,whats the labour involved in removing camber arms,pressing out bushes, pressing in new ones, re-installing arms.Cheers GREYPEARL.
Im actually in NSW on the Central Coast, its not a shame at all...:thumbsup:
Id get both front and back done Im pretty sure if your fronts dont have a camber kit you will be needing one as well to get the perfect camber setting on them, Im using both front and back and Im at a similar ride height to you as well and got the suspension then aligned by a suspension workshop that handles alot of rally and track cars, very noticeable difference once it was setup properly.
Its easy to remove the arms couple of bolts, may need a good breaker bar or extension though, I took the arms down to a local suspension workshop and get the old bushes pressed out and new ones pressed in for $50 and then went home and installed the arms, I also did my sways and coilovers at the same time and then went and got it all aligned... I like doing the work myself and also saving money win win really from my perspective...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
