car is fitted with stock turbos/actuators, rear one opens with minimal air pressure (as tested with air compressor and regulator), the front one however requires like 20psi before opening, then i can actually open and close it quite freely until it fully closes again.
to me seems like something inside the actuator is binding before allowing it to open fully. If i assist the movement of the wastegate arm, again it comes out easily. There is no air hissing from inside it, so the diaphragm seems to seal just fine.
I dont know really what they look like inside, but i can't think what it might be binding on. any suggestions? I haven't used these turbos before, so its possible that the wastegate housing was deformed in transit, the vac nipple on one of them was bent over a bit, could have been this one possibly, but unsure.
If the wastegate housing is slightly deformed, would this cause the issue (ie the internal "piston" or whatever is there is catching on the inner wall of the housing, until being freed by more backpressure)
the actuator housing doesn't APPEAR deformed but if i can't find a solution, i'll take it out for closer inspection, but that will be a c-word of a job, not much space in this bmw engine bay.
thanks all
chris.
You need to remove the circlip from the actuator arm and test the movement of the actuators without them pushing on the arm.
If they dont operate identically then you should replace them both so they are matched.
Yeh cheers. The test was done with the arms detached from the wastegate, seems i've fixed it tonight, the vac nipple on the actuator was likely damaged in the mail, i thought i bent it straight again but still was a bit misaligned, got it nice and straight with pliers and now the arm moves unrestricted and in unison with the other actuator.. Not sure why this would affect its operation, but seems to work well, again using the compressor and air reg, they both start to open from 5-7psi and fully open around 10 which i think sounds right..?
I love these cars!! Back to the dyno now.
christo.
There is a rubber diaphragm in side those actuators. If the diaphragm leaks then it will not/hard to open by vacuum pressure. See if you can blow air through that actuator. If so it means its not good.
good choice to test them BTW....I tested some the other day, 1 opened at 12psi, the other at 15psi. ie one turbo would have spent it's life working 30% harder than the other. brand new actuators
I used a compressor, with a regulator keeping it under 20psi, and a bleed valve. T-piece for a boost guage. Set it to 5psi, link it to the actuator and slowly close the bleeder until the arm moves.
I understand the adjustable length of the actuator only adjusts the preload on the wastegate, should be 3-5mm. I guess that affects the boost by maybe 2psi? But I don't see how it can be really "adjustable" far from the preset tension of the diaghram
  • 4 months later...
just found out i got adjustable wastegate actuators on my -7's
with my profec off tthey boost to about 9ish psi so most likely set to 7psi
how do you go about them holding higher boost? tighten the arm thus making it shorter? or lenghten the arm by loosening the bolt?
il do the compressor/air reg test to see how they perform aswell
    • ..could be worse... but out here, renting private affords some luxuries ...we've even been told the Sept dateline isn't critical, and I'd rather move stuff in the cool of winter, than slogging it out in the heat. Recall we were talking about the million dollar view this place has?...that's what he got for it... (won't be so nice when the quarry happens at the back in the future...lol..)... ...cool, I'll stick the wiper motor in a wee box...umm.... the pinny is GLX trim ~ I think that's about as close as it gets to Silo spec when it comes to the S2 pinny...ie; electric mirrors etc etc...dunno about the trip computer/wiring...I do electronics repair, I'd be willing to take a look at it for you. As you saw, all the dash is there in that car..and thinking about it, it'd be easier to pull the whole center section out, rather than just the ashtray and rails, but your call...
    • The "sacrifice of low end" is now basically irrelevant in 2025. Turbo/ecu/fabrication/and other tech advancements gives a vast array of options to mitigated any of it. My setup now is a fantastic example of this. 300whp / 20psi @ 3500rpm from a 600hp turbo setup on a notoriety low reading Dyno Dynamics roller dyno, is almost unmatched on all of SAU and other forums. The only other turbo i've seen that can achieve this is a BW EFR + twin scroll / twin gates etc etc etc... ps. tuned by Matty Spry at P.I.T.S as far as getting to the 600 figure, while enlarging your itb's alone probably won't get you there, as Sucram has stated above, it will certainly help. Just do it Predator1 my brother hahaha 🙂
    • I use Taaarks/efi solutions ones. Years, and no issues.
    • At the Botany heavy vehicle inspection centre. At the time there were only 2 locations that did IM240 testing for free, the other location was at Penrith. I did a quick google, seems like the Botany and Penrith inspection centre is closed now though About an hour of my time.  At the time you could. They are closed now   No it was Government run, the site was attached to the RTA from memory. The guys running it at the time were awesome, if you didn't pass the test, they handed you the results and said make changes to your car/tune and have another go later. You drove in registered, failed, and drove out registered.   Obviously though if you were defected, sent there, failed. You remained unregistered.  From my 5 minutes of research (have a look at the date on my test results) looks like things have changed. So, I can't see any way to get this test done for free now Seems like you'll need to call around the engineering places doing the Vehicle Safety Compliance Certification Scheme or call around workshops with a dyno and try and get a RG240 test. No idea how expensive that is though or how easy it is to find a place offering it.  Bit depressing learning about this now. The first car I had engineered in NSW cost me about $250 all up.... So kids these days can't buy houses, looks like getting your car legal and engineered in NSW is another thing on the list of things they can't afford. Great.
