yes you can get it with aero
no its not eligible for compliance.
weird, probably converted for P plater, or someone has sneaked it into the country and passed compliance.
or the dude is WAAAAAAAAY wrong and has no idea
LOL so just a VQ25DET without the turbo...ha
He's selling a couple of unregistered M35's...dodgy backyard importer :down:
Although the 250 AR-X is not technically eligible for compliance it MAY have some how slipped through the cracks. Ive heard of it before. A VIN number would also confirm it (Someone can FAST it). Im sure you could just email the dude for either of those details, for morbid curiosities sake :P
for a start its not an AR-X dunc :P
trustworthy?? eerrr no lol
lol indeed.
The car doesnt have any markings on the rear hatch which wouldn't aid in identifying the model number I guess. Its certainly an oddity.. would definitely want a very thorough inspection of the thing done if you were looking to buy it.
personal import? Apparently is registered...?
might have just found the cheapest way of not buying a new turbo! dont replace it!:nyaanyaa:
Doubt it...why does he have 2 M35's for sale? brought back 2 cars from Japan?
check this one out
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=0&R=9857047&keywords=&trecs=43&__sid=12C9CF966E63&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&__Qpb=true&tsrc=allcarhome&__Nne=15&seot=1&__N=1216%201246%201247%201252%201282%204294963846%204294960181%20898&silo=1011
ARX with AXIS kit? What sorta mod is that with the manual transmission lookalike?
lol... problem is an 8.5:1 comression... in a 2.5L... in a 1600kg+ car
Just a leather bootie with a large round knob on the selector... looks a bit ghey IMO :P
lol indeed.
its clearly an RX
has electric fabric seats :)
an engine shot would fix this discussion right up
personal import im sure its possible
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
