Just to add to the cause, when i bought my 33 GTS my friend bought it up from Melbourne. When it arrived, it was sporting GTR badges on the guards where the GT badges were supposed to be and poorly fitted GTR Rear pods. Epic fail, and they were pulled of very quickly was actualy ashamed to drive the car til they came off :S
Good work
wow, i opened this thread expecting to see pics.
fail.
and because im quite the joker and my car was quite the joke (to my delight).
i didnt necessarily like the GTS badge and seeing as i had a 400R bar i got a genuine R33 GTR badge from nissan and had a custom NON made up.(i later on sprayed the IC brackets black and then it looked schmick :) )
so this was my NON-GTR(R.I.P.) :(
haha damn gtr badges. my so called "mates" decided to put a gtr badge/sticker thing on my car when i didn't know - i saw it the next time i took my car out of course, but still in that time if it was seen.....:down:
Edited by kaitoukid
fail.
That badge is FAIL
the fact that you had to quote my whole post including 4 large photos is fail.
i achieved exactly what i wanted to achieve with that badge:pure ridiculousness.
At least you admit the ridiculousness. +1 for that one.
  • 4 weeks later...
Going back to Holdens with Chevy badges...
Looks like they are even putting a bit of effort into it now. Now nobody will know its a holden...
Its like what someone else said earlier, the only person they are fooling is themselves. People that don't know don't care, and people that do know think you are a tossa...
how bout you bugger off aye?
this thread is in no way about anything that isnt about GTR badges being put on GTS skylines.
capiche?
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
