I read there was a compartment at the rear of the wagon to hold some sort of hyraullic fluid. Is this true for my model, as I cant locate anything.
I can locate compartments on either side
Do any of the stageas have hydraulic suspension?
Behind the RHS cubbyhole in the load area there is a reservoir for the ATESSA system.
You have to remove the cover, and grab the lip of the plastic insert and pull (fairly forcefully) and it will pop out revealing the reservoir inside the rear quarter panel.
The first time I pulled mine out, I thought I was going to break it, then it just popped free.
Checked Aaron's attessa reservoir last night, it was black. Looks like I have to work out how to replace the fluid and bleed it. Any ideas?
I guess I have to suck out what I can then bleed it from the nipple on the transfer case, any idea how to get the pump to run continuously?
I wonder if it uses a pressure switch and an accumulator to maintain pressure in the system? I'm pretty sure this is how the r33GTR does it, and when the accumulator dies, the pump switches on and off constantly to maintain system pressure.
If you draw the dirty fluid out of the reservoir, replace with clean, then start the engine, the pump should start to charge the system with pressure.
If you open the bleed valve, the system may start to lose pressure and the pressure switch should activate the pump.
If this happens, you might be able to crack the bleed nipple with a length of hose to drain and slowly bleed the system until you are getting clean fluid, while someone is watching the reservoir level, and topping as required.
Sounds reasonable, just changing the fluid in the reservoir would be a good start anyway. Normally the dealer would switch the pump on with the consult 3 I guess.
Changed the transfer fluid yesterday, Aaron typed up a how to. :)
http://www.m35stagea.info/forum/viewtopic.php?f=6&t=139
will probably be similar to c34's
look for a plug under the dash, 1 wire in 1 out possibly green
unplugging that and turning the ignition will keep the motor running
you can also take the fitting out of the back of the transfer case and run the motor, this will drain the fluid faster
thats strange because if i unplug it and drive normally the 4wd light comes on
if you unplug it and pump the brake pedal 5 times then you get in rwd mode (for c34's this is, but i doubt m35's are much different)
m35 should be using a similar system (attessa-ets)
take note of the "air evacuator connector"
Edited by pipster11
It's worth a look but normally there's some annoying reason why what works on a c34 simply won't work on an M35...pinch.gif
well you guys have a super crazy motor ecu but the awd system sounds very similar so i don't think the control of it would be much different
Except me... over here in electric clutch land!!!:happy:
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
