Lol when you said on board computer, I thought you meant the ECU lol.
If you meant a MFD (multi functional display), like this one:
Then I bought mine for $800 2nd hand, they range from $700-1000. And it took me 8 hours to wire it up, considering that I have NO experience with electronics, never installed a headunit before lol.
I think if you were to get someone to do it, it would cost like $200-300.
Yeah that. ive always loved the look of it and the fact it has everything. where about would i be looking to purchase something like that and how big a wiring job is it?
There's one on sale on SAU (for sale section) I believe. As for other places, maybe wreckers, private sales or from Japan.
As for "it has everything". To be honest with you, I think the MFD is overrate lol, if I have a choice now, I wouldn't have bought one, would rather spend that money elsewhere. But I guess the MFD would raise my resale price if I was to sell my car.
As for wiring. You will need to splice into your ECU harness, triple gauage harness, speedo cluster harness. There's probably about 10-12 wires you need to locate and splice into.
But I do see your project being a more difficult job. Because with stock GTT's, they come with the triple gauage cluster, which is hooked up to the boost, and oil temp. Which a NA GT wouldn't have (the triple gauage & harness). That would mean that you'd have to locate those things yourself and splice into it. Because if I remember right, the MFD splices into 3-4 wires in the triple gauage harness.
I honestly reckon you shouldn't do all that to a NA R34. If you are on your P's and restricted to a NA, then you should just keep the NA until you are off your P's, then sell it and buy a GTT. Because the price difference between the GT and GTT is barely anything. And that way, you wouldn't have to muck around with upgrading all the brakes and stuff. It will also be a cheaper way to go.
Yeah your probs right be much easier to just wait till im off my p's. plus if i dont spend the money on the MFD it means i can put more towards sound and shit. thanks for the help mate.
Also it seems you think that you can just get an N/A car and put a turbo in. You cant just place a turbo on a non turbo engine in case you didn't know, you need to upgrade everything under the bonnet, it would probably cost more than a gtt itself.
yeah i know but wasnt sure that a gtt was roughly same price until mentioned above, and figured i was doing it the cheaper way till i researched it
Just make sure you do enough research before buying a skyline, since you don't know too much about it. Regarding insurance and what's legal and what's not etc etc :P
yeah im pretty much set with research i got two friends that are heavy skyline fans and both own r34's. im thinking cause i love the 4 doors il keep my first one stock and once off p's keep it and get a gtt. or can you buy gt-t skylines in 4 door?
Yes... GTT does come in 4 door... Pretty commom too. But manual ones are harder to find.
really? like hard hard to find? also how much do you reckon i would i be looking at spending for a 2000 Gt-t 4 door in manual with low k's
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
