Lol when you said on board computer, I thought you meant the ECU lol.
If you meant a MFD (multi functional display), like this one:
Then I bought mine for $800 2nd hand, they range from $700-1000. And it took me 8 hours to wire it up, considering that I have NO experience with electronics, never installed a headunit before lol.
I think if you were to get someone to do it, it would cost like $200-300.
Yeah that. ive always loved the look of it and the fact it has everything. where about would i be looking to purchase something like that and how big a wiring job is it?
There's one on sale on SAU (for sale section) I believe. As for other places, maybe wreckers, private sales or from Japan.
As for "it has everything". To be honest with you, I think the MFD is overrate lol, if I have a choice now, I wouldn't have bought one, would rather spend that money elsewhere. But I guess the MFD would raise my resale price if I was to sell my car.
As for wiring. You will need to splice into your ECU harness, triple gauage harness, speedo cluster harness. There's probably about 10-12 wires you need to locate and splice into.
But I do see your project being a more difficult job. Because with stock GTT's, they come with the triple gauage cluster, which is hooked up to the boost, and oil temp. Which a NA GT wouldn't have (the triple gauage & harness). That would mean that you'd have to locate those things yourself and splice into it. Because if I remember right, the MFD splices into 3-4 wires in the triple gauage harness.
I honestly reckon you shouldn't do all that to a NA R34. If you are on your P's and restricted to a NA, then you should just keep the NA until you are off your P's, then sell it and buy a GTT. Because the price difference between the GT and GTT is barely anything. And that way, you wouldn't have to muck around with upgrading all the brakes and stuff. It will also be a cheaper way to go.
Yeah your probs right be much easier to just wait till im off my p's. plus if i dont spend the money on the MFD it means i can put more towards sound and shit. thanks for the help mate.
Also it seems you think that you can just get an N/A car and put a turbo in. You cant just place a turbo on a non turbo engine in case you didn't know, you need to upgrade everything under the bonnet, it would probably cost more than a gtt itself.
yeah i know but wasnt sure that a gtt was roughly same price until mentioned above, and figured i was doing it the cheaper way till i researched it
Just make sure you do enough research before buying a skyline, since you don't know too much about it. Regarding insurance and what's legal and what's not etc etc :P
yeah im pretty much set with research i got two friends that are heavy skyline fans and both own r34's. im thinking cause i love the 4 doors il keep my first one stock and once off p's keep it and get a gtt. or can you buy gt-t skylines in 4 door?
Yes... GTT does come in 4 door... Pretty commom too. But manual ones are harder to find.
really? like hard hard to find? also how much do you reckon i would i be looking at spending for a 2000 Gt-t 4 door in manual with low k's
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
