Hey guys, was driving last night launched my car hard and couldn't select 2nd. Pulled over and turned my car off. Car starts in neutral but I can't select gears, if I turn the car off I can select first and try start it with my foot on the clutch but it's like it's stalling. Any idea on what is wrong? Clutch is a Jim berry full Monty that I've done about 15-25,000 I'm on it
https://www.sau.com.au/forums/topic/350407-blown-clutch/
I'm guessing that might be the pivot fork squeeking from no lubrication or is the squeeking in the cabin? Just to rule it out check your clutch pedal bracket to make sure it isn't cracked or broken. If that's intact and working properly then it's probably your clutch that's gone.
https://www.sau.com.au/forums/topic/350407-blown-clutch/#findComment-5626007
I've had this happen once when down shifting in a previous car (r33 gtst) it ended up being
the pressure plate fork bending and the dampener springs coming loose.
threw a new clutch kit in and it was all sweet.
I could Select all gears with car off and not running.
Very difficult Gear selection into any gear with car running.
it sorta happens when you downshift from 5th to 4th at high rpm. but accidentally go from 5th to 2nd :(
https://www.sau.com.au/forums/topic/350407-blown-clutch/#findComment-5626182
read my thread, same issue, it was flywheel fusing itself to the clutch plate.. same symptoms as yours..
yep this is exactly the same thing I think I described in your thread..
OP you've spot welded your clutch plate to your fly wheel, done it heaps of times with jims clutches and surprise surprise another broken a gearbox with one of these clutches
anyway put it in first, start it ( it will lerch forward but will start) put your foot on the clutch take it up into the boost zone and nail it. it will brake free.
but after that many kms the clutch could be stuffed anyway, but maybe not if you've only done 6 launches (think I read that)
the welding thing happens when you slip the clutch for too long and it gets really hot
https://www.sau.com.au/forums/topic/350407-blown-clutch/#findComment-5629444
Definitely a clutch related problem, but don't rule out the following which are IMO more likely to be the cause:
- Clutch fork pivot ball could be worn, very common issue in all Nissans...can be replaced with a $70 Nismo item but the gearbox needs to be taken out to do it. Precursor to (and after) this failing is a fair bit of squeaking when moving the clutch pedal in and out.
- Leak in the hydraulic system, e.g. faulty slave or master cylinder.
https://www.sau.com.au/forums/topic/350407-blown-clutch/#findComment-5635948
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
