Hi Guys/ Gals
I'm selling mt R34 GTT Tommy Kaira Cluster, a little bit of background on this, i bought it off a forum member sometime ago, unfortunately i didn't receive the main cable that allowed me to connect to the GTT wiring. Instead i spent a bit more money to have the wires figured out by an auto electrician.
Anyways after having majority of wires figured out i was able to get it working. The only 2 things i was not able to figure out were the wires for the shift light and peak torque light.
Everything else works on the cluster with no issues. I will provide also 2 SINE Wave boxes which have been calibrated for the cluster to work and read correctly, for some reason the ODO and RPM was reading out. This will be sold all together with the cluster, i will also provide the details on what each wire does and wiring diagram of the GTT cluster excluding a few (shift light & peak torque).
Cluster is showing 147536km on the ODO
Asking price is $600 ONO
Pick up for now.
Contact me via PM or on 0402 292 385
Edited by Grimmjow
https://www.sau.com.au/forums/topic/350436-r34-gtt-tommy-kaira-cluster/
Pitty you could not get it all to work.. Looks crazy...
Yeh man, been spewing about the last 2 features, in the end i couldn't get it to work but maybe other people on the forum may have better luck....
This guy looked to be desperately after one if you were willing to ship overseas
http://www.skylineowners.com/forum/showthread.php?p=1585078
Thanks for the link mate, but i don't really want to ship overseas at the moment
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
