Hi Guys/ Gals
I'm selling mt R34 GTT Tommy Kaira Cluster, a little bit of background on this, i bought it off a forum member sometime ago, unfortunately i didn't receive the main cable that allowed me to connect to the GTT wiring. Instead i spent a bit more money to have the wires figured out by an auto electrician.
Anyways after having majority of wires figured out i was able to get it working. The only 2 things i was not able to figure out were the wires for the shift light and peak torque light.
Everything else works on the cluster with no issues. I will provide also 2 SINE Wave boxes which have been calibrated for the cluster to work and read correctly, for some reason the ODO and RPM was reading out. This will be sold all together with the cluster, i will also provide the details on what each wire does and wiring diagram of the GTT cluster excluding a few (shift light & peak torque).
Cluster is showing 147536km on the ODO
Asking price is $600 ONO
Pick up for now.
Contact me via PM or on 0402 292 385
Edited by Grimmjow
https://www.sau.com.au/forums/topic/350436-r34-gtt-tommy-kaira-cluster/
Pitty you could not get it all to work.. Looks crazy...
Yeh man, been spewing about the last 2 features, in the end i couldn't get it to work but maybe other people on the forum may have better luck....
This guy looked to be desperately after one if you were willing to ship overseas
http://www.skylineowners.com/forum/showthread.php?p=1585078
Thanks for the link mate, but i don't really want to ship overseas at the moment
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
