hi all this is my first skyline build so thought what better place to post it up then on SAU , any advice or recomendations is more than welcomed as im still learning with these cars.
well i gues i better start off on what it is and whats planned
1999 R34 skyline gtt
motor - rb25det
mods - *From what we can see , not from what the hpi magazine issue states*
-apexi gt series turbo - similar to a 3076 with .64 rear housing
-apexi cat back exhaust with titanium lip muffler
-possible injector upgrade
-splitfire coil packs
-autosport aluminium radiator
gearbox-
some sort of twin plate clutch still working fantastic
suspension-
gab shocks
some sort of springs
whitline sway bars
hicas lock bar with everything all neatened up
wheels-
18 inch Volk Gtc in gold
audio-
sony deck
front speakers
body -
wing removed *holeswelded up*
carbon fibre bonnet
interior-
aftermarket gauges in single din slot in dash
recaro millenium bucket seats
recaro seat rails
no rips or tears or scratches
blitz electronic boost controller
current performance - 240kw atw on 19psi - 231kw atw on 16psi on smd dyno in revesby
pretty much since i bought it 3 months ago i have attended a few private drift days and had a hell of a time , but the true intention for this car is to be used for circuit work
up coming mods-
half cage
remote oil filter + oil cooler
some sort of semi's still searching
these will be happening in the next few weeks.
i will be looking into suspension mods as it goes through
https://www.sau.com.au/forums/topic/350437-r34-gtt-hpi34t/
  • 3 years later...
Forgot to update this thread lol
Put on a front lip carbon boot z tune skirts and rear pods
18x9.5 and 18x10.5 varrstoens
Had the whole car resprayed after a incident where the passenger rear quarter and front guard met a pole and fence lol
One of the best handling cars I ever owned still regret selling it after seeing it covered in stickers and no lip :(
https://www.sau.com.au/forums/topic/350437-r34-gtt-hpi34t/#findComment-7306253
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
