Ok so as promised, I have a heap of overlays. I'll explain it all as below.
Common items/points
- All cars are Racepace builds, of near similar specification. These will not alter results massively at all.
- All using stock cams (except 517z car), similar head tidy up, RB26.
- NO EBC's are being used, just the same modified actuator setup
- All cars are run on the Racepace Dyno. Calibrations are the same except one graph where the boost reading is 50% less. Explained later.
- All cars are run using the SAME set of 18's, with the SAME set of tyres on them (dyno wheels), and are all in RWD.
- All tunes are track focused, they all run a slightly safer tune than a street tune normally would.
- All cars run factory airbox, and at least 3.5" exhausts, stock exhaust manifolds, stock plenums. Most have factory dumps also
- Most cars are R33 GTR's, stock drivetrain specs. There is one R34, so obviously some difference there
Turbo Specification & other info I will just go in order, top to bottom.
Dark Blue - Custom Racepace hybrid turbo's. I will find out specs later. (It's my car)
Light Blue - Garrett -9 / boost control issues. Car has run 124mph @ Calder in this config.
Green - Garrett -5. This motor is slightly different to all the others in terms of specs (ie, better)
Red - Trust T517Z 8cm. On graph, boost is 50% less than it was. So just double it, sensor was not reading correcly. 260° 10.8mm lift cams
Pink - Garrett -7
Black - Garrett -5
Comments:
Once the -9 car's boost control is fixed, I'll get more plots.
As you can see, the -7s and -5s spool almost the same on the dyno under load, however there is a noticeable difference when on the street that is not possible to show here.
My custom turbo's however are rather crazy in terms of response, however they do fall over in upper RPM's harder than the others. I will get EVC6 just to see if there is not more that can't be done. Even 2psi extra as it falls off would make a huge difference.
About all I can think of for now. Thanks to Chris @ Racepace for spending a good 45mins today going through over 100 graphs to find the correct/final results of cars. Some cars had over 300 runs in the database, so it took a while :)
And Troy/(Roy) was down there hassling us to put RB20 graphs on there constantly :D
https://www.sau.com.au/forums/topic/350440-dyno-comparo-various-twins-rb26/
What I'll try to do as well in the future is get some video on road in various gears with 2-3 of the cars side by side @ the same time etc.
That will further help to show the difference in response/pick-up that's hard to see on a loaded up dyno run etc.
That could be a little whole though as a couple of the cars above don't exist in those setup's anymore. Especially -5 cars, both of those now have -7s on them.
Ye, he is the mate/car i was telling you about.
I won't be putting any larger displacement though. It's just for 2.6ltr's at this stage.
What i will do though is get a mate of mine to touch the graph up in Photoshop to make the lines easier to see the lines.
My boost curve for instance gets a bit lost with the power lines :D
If someone could work out the RPM points @ the KM/h point, i'll add them in as well for easier reference.
Not sure what the point of this thread is - but I can say my 3yo daughter drew a pretty picture like that one as well earlier today :)
For what it is worth the black one I think is my old 2007 Dutton set-up. Now Ash mentioned it was going to be "different" because it was in an R34 but infact that would have been from when it had the full R33 drive train in it so it really should be comparable.
Funnily enough we have noticed that there is a small drop in power on the dyno and a shift in the curve line to the right when we went from the R33 drive train to the R34 drive train on the N1 set-up. So it seems you can't ever really compare an R34 to R33/R32 graph on the same dyno exactly. (Be an interesting one to try and dig up and show one day too).
Ah ok 33 drive - cool ill alter it then :)
Point, no real point i guess.
Just to see what varying setups look like @ what boost range. All the turbos are good for over 20psi without a problem on good motors, even the smaller ones even though they fall over a bit.
But ye Noel, the -9 equipped car there and another -5 car (similar spec) had rolling runs a few times and from a off-boost and the -9 car was pulling ahead in the lower gears/speeds no problems.
Id rather test that myself and video it :D
Nice work Ash, good to see how the various turbo setups behave on Racepace engines. The Trust turbos are the T517Z 8cm version, exactly the same as what I had back in the day. Now you can see why I went to -5's instead. The Trust turbos make good peak power but lack the low end response...
Ah right, well in that case from remembering what you said; hurry up with it!!! Lol. I'm keen to see the results from that one
I'll wait for the stroker overlay thread :D
ash can you add in the the detals... such as if the engines have been rebuild because there is 20-50 rwkw in a 20 year old rb26 with nasty blowby
for example one of my gtr's rb26 with -5's and 1.2 bar = 280 rwkw, blowes the dip stick out regualry so much so i run 12 pounds at the track and cable ties to hold the dip stick f**ker in
i know the same engine with a hone and new filed down rings will put out 320rwkw even with the same awesome nissan factory pistons
and 3 litres in r31's are for posers
ya fags!
ya fags!
All the engines above are rebuilt by Racepace.
Ash, good work.
How come the one with -9s has boost control issues?
I'm curious on how -9s with boost control issue fixed would stack up compare to -7s in terms of response.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
