How come the one with -9s has boost control issues?
I'm curious on how -9s with boost control issue fixed would stack up compare to -7s in terms of response.
Don't know. Mate of mine said mine was quite a bit more responsive than his, given our turbos are similar, we now know why.
No doubt he'll get it fixed eventually. Could be 100 things.
Ash, great effort on the comparo this is exactly what makes this site useful.
I'm looking for turbos at this stage and your turbos seem very appealing, theyre more responsive and overpower the 9s. Boost issues aside, the 9s seem to be behind these hybrids by some way.
Do you know if race pace will be selling these offshelf?
With a GTR, it's more like 10,000 things!
Yeah yours look as responsive as, wouldn't mind having a ride in it.
I'm curious on -9s being bit laggier than -7 from my exprience, it's the other way. But I'm comparing 302rwkw GT-SS to 270rwkw R34 N1 with EBC, but I'm comparing apple with orange here.
All I know so far is they are 4 GT2860's made into 2.
Given Garrett don't sell the wheels separate to the cartridge for that series... So it gets very expensive quite quickly.
When I find out more I'll update.
Garrett don't sell separate but you can get individual parts for Garrett turbos elsewhere.
SimonR32 would be interested to see your old T04Z graph I know it is a twins thread but just for comparisons sake as you had it pretty sussed out. Or maybe the thread should stay on topic a bit longer :)
Similar to the 517z's up to about 120 then ramps hard and monsters everything... But yes stick to low mounts for now :)
I discounted this because it had the better motor, but still same turbos :)
Really the major difference between the 2 is the amount of boost they are running.
Either way - they were both good track set-ups thats for sure. For everything else I'd prefer Ash's one.
  • 1 year later...
Apologies for the MAJOR thread revival, but I don't think anything else has been mentioned about these Racepace Hybrid turbos on this forum according to what my search results are showing.
Was the EBC eventually installed to see if there was any difference? (especially after the boost curve of this setup crosses over with the -7 setup, if it were able to at least maintain 19psi like the -7, that would be interesting to see)
Was there any further development into this setup?
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
