Hey all
Have finished running in the 3.0 motor and it's all good, except the extra torque has exposed some limitations with the chassis/suspension setup.
So I'm not getting anywhere near full throttle on corners, it's lighting up all four at around half throttle or 2/3.
We took it for a run today and came out of a corner in second, then floored it til the posted highway speed limit, and the steering got really, really light and the nose started lifting. Not just the rear end squatting under power, but like the nose of the car really coming up. Kind of relying on the back diff locking up to keep it in roughly a straight line.
Now I know in the absolute worst case (like in drag cars etc) the front wheels can actually come off the ground, but I've only ever seen that in cars with really light motors and really short wheel bases, like rx3's and the like. I would have thought that with a comparatively mild 3.0 motor I'd be pretty safe from all that, especially with a long wheelbase and a big lump of cast iron in the front.
now obviously we aren't allowed to go driving around with a wheely bar, just wanted to know if I have something obviously wrong with my suspension before I go upping the boost etc. Have other people experienced this and what are your solutions? My current suspension setup is nice for cornering but not much good for exploiting the straight line characteristics of the motor.
Cheers
Andrew
320kw, 600nm.
Suspension is what came with the car (i/e don't know the spring rate etc) - not coilovers, but towards the very firmest spring rate you could get. Definitely neither springs nor shocks are sagging or flogged.
Tires are 235 all round.
I agree, something is amiss, heaps of other people have posted power/torque figures well exceeding mine, I just need to get pointed in the right direction to start looking at suspension etc. or alternatively wondering if it's a common problem people have experienced.
What suspension is in there? Spring rates?
What kind of power are we talking here?
Something doesn't seem right.
My old R33 gtst would lift on high boost and steering would be weightless to say the least. I found out I had adjustable suspension so I raised the back up a notch which firmed up the arse end and hopefully put the center of gravity further up the chassis. I was only making about 240rw and 580nm.
Firm up the rear and try get the COG forward.
What an awesome problem to have, Up your dampening rate and it will help with anti squat. actually just realised you dont have coil overs so you cant easily
To much droop in the front suspension will cause you to have this issue as well. as the front lifts it gains momentum and this can make it go higher than it normally would. Reducing droop stops it doing this. But really if you have stock style suspension your going to find it hard
Thanks for all the replies, I'm a noob when it comes to suspension.
I thought the springs were about as hard as I could live with but then I thought about it and it's really the front springs that shake you around when you go over bumps etc so firming up the rear end shouldn't affect driveability and ride too badly.
I think I'll have to start looking into adjustable coilovers at this point rather than trying to experiment with the standard style setup.
can you measure from the centre of the wheel to the guard for both front and rear? this will tell us more about the spring heights in there now. also have a good look underneath, or give us pics of the shocks and springs.
it is very possible that old, standard shocks and springs will allow heaps of squat
Hey all
Cheers
Andrew
I know this doesn't help you but you can't say it was all displeasure!
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
