Hey guys,
I've got a 1995 Nissan Skyline GTS-4, I'm looking at buying a 1999 RB25DET Engine from a Stagea just wondering what factory ECU I'd have to run, eg. R33 GTST being mines a Series 1, R34 GTT as its a Neo Engine...??
Thanks in advance guys
Dan
https://www.sau.com.au/forums/topic/350471-help-needed-with-ecu/
Thanks mate, got an email from Chequered Tuning saying I can run Neo Loom and ECU from what was on the engine originally or R33 GTR PFC modified for it to work.
I've been told its all parts required to drop in the engine so I'm guessing thats including loom/ecu :)
The 99 stagea has the RB25DET neo and the ecu from that series stagea has the same pinouts as the R34 GT-t (excluding the traction control pin 51...unless it is one of the 2WD versions).
On the cost side you would need the loom, ecu and Nistune board to be in a similar position to getting the R33GTR PFC modified and wired up.
It depends on price but a either of the options from Chequered will be a good thing.
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
