Hey All,
Slowly getting the AE86's engine swap under way and I will need to move the clutch master cylinder off the fire wall as it will hit the right hand bank of the engine, after much faffling about with KE70 clutch pedals and stand alone boxes form tilton and the likes I have figured that the simplest way to do this would be with a pull type master cylinder, while i have found that AP racing make one its supposed to be approx $500 i also saw that some skylines may use a pull type cylinder.
Is this true?
If so what models use this and if any one has/can get me a part number or pictures of it that would be appreciated as ill be asking wreckers for the parts and Ive found they tend to grab what ever is generally closest thing that may do what Ive asked for.
Cheers
  • 7 months later...
I take it you are talking about the master cylinder and not the slave cylinder which is used to disengage the clutch by either pull or pull action
If it's the master cylinder and space is an issue you get whatever does the job
Late R32 GTR, R33 GTR, R34 GTT and R34 GTR are all "pull" type clutches but the difference is in the slave cylinder (pull on the fork as opposed to pushing), not at the master cylinder.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
