hey boys need abit of help my r32 gtr (running 12pound boost pretty stock with pods and an exhaust) when it hits hgiher boost and higher lvl of rpm as in about 4500rpm the revs start to break up and the car has no power. only started yesterday morning and has been doin it ever since. people ive spoken too reckon it could be an electrical problem with the air flow meters??
any advice/oppinions are appreciated :)
Thanks, Chris
https://www.sau.com.au/forums/topic/350517-gtr-problems/
Gday mate,
Common problem that is usually coil packs or even the ignition amplifier, especially if they are still the original stock R32 GTR items. Mine had the exact same problem as did a mates.
I've even had an AFM problem however that went into a limp mode and limited the revs to around 2800rpm.
Hope this helps mate
https://www.sau.com.au/forums/topic/350517-gtr-problems/#findComment-5626966
If it is just one coilpack then you would be better to replace the whole set as they are all the same age and if one goes then there would be a high likelihood that the others would go too. It is difficult to isolate coilpacks because disconnecting individual coils may show no difference over 4500rpm but it will create a miss in the whole rev range, just confusing the whole situation, lol.
Your best bet would be to find someone else with a GTR and to do some part swapping to isolate the various ignition system components.
https://www.sau.com.au/forums/topic/350517-gtr-problems/#findComment-5627030
thanks mate i just took it for a drive and noticed that it doesnt do it when the clutch is engaged or it is out of gear??
yeah that would be right as the engine is under no load whilst out of gear, over 4500rpm and the the engine is under a decent amount of load
https://www.sau.com.au/forums/topic/350517-gtr-problems/#findComment-5627315
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
