People need to be able to edit their original posts in the for sale section.
I know it sounds a bit crazy, but I think it'd be easier if prospective buyers only had to read the seller's original post. Rather than having to read the original post then scour the rest of the thread to see which items have been sold or had their prices changed.
Thank you for considering this wacky and unconventional suggestion.
Sincerely,
Common sense
https://www.sau.com.au/forums/topic/350523-news-flash/
Scammers tend to edit their first post after having ripped people of hudreds or thousands of dollars, making it impossible to be of any assistance afterwards.
As a side benefit, it also enforces sellers to adhere to well thought out, logical sale posts rather than a half arsed effort that is of no use to anyone.
If this seems disadvantageous to you, then by all means create a second "placeholder post" for future updates.
Thanks for your suggestion, but this feature is the result of operating under various arrangements for over 6 years. This is the optimal result, deal w/ it.
Kind regards,
Reality.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5626987
Ahh, good point. People can't scam if they can't edit.
Wait, no..
How familiar are you with MySQL and MySQL dumps?
If a copper contacted you about some poor schmo who spent $5k on a non-existent turbo kit only to find that the original thread was nowhere to be found, reckon you'd be able to trawl through 100+GB of mysql dump files to find the original thread and post?
Oh wait, but what if the thread was made and deleted between backups?! What will we do now???
I see you put a lot of thought into your suggestion, but you could have also put the same amount of thought into PM'ing a moderator of the for sale section to request they change your thread.
We're not exactly new to all of this. :)
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627068
wow triple threat smackdown.
lol Dvus its been discussed heaps and its the most manageable solution. PM a mod or admin if you need massive changes, or in future post a placeholder ppost after the first post for updates.
triple threat. so hot right now.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627076
What's triple threat?
Speaking of SAU's role in hunting down forum scammers, I read this somewhere;
"Skylines Australia takes no responsibility for transactions that occur as a result of this forum. CAVEAT EMPTOR - BUYER BEWARE!!!"
Anyways, I had a feeling I'd end up getting into a cockfight by posting feedback in the feedback section. Jokes aside though, I just wanted to put it out there as a matter of principle, not because it's a big issue for me. Thank you for your explanations.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627235
I suppose your local paper should be responsible for every item they advertise in the classifieds too.
No we're not responsible. However, we do like to take time out of our normal schedule to help those who have met with irresponsible sellers.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627244
Well it's been put out there in 10 pages of the thread that already covers this
http://www.skylinesaustralia.com/forums/topic/341192-cant-edit-posts/
Thanks.
https://www.sau.com.au/forums/topic/350523-news-flash/#findComment-5627323
Guest
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
