Below is a list of the parts I have for sale. It has everything you need to do a timing belt and water pump change. I also have some Cam cover gaskets because they normally leak and I believe your meant to adjust the clearances at about the 100k mark as well.
  • Timing Belt & Water Pump Kit (Genuine Nissan Cam Seals, Genuine Nissan belt and Genuine Nissan R34 water pump
  • Genuine Nissan Timing Belt Stud Kit
  • Genuine Nissan Cam Cover Gasket Set
  • Genuine Nissan Ancillary Drive Belt Set
  • 1 Trust/Greddy Oil filter + 1 Ryco filter I have here
  • 1 tube of gasket maker stuff.
I paid Kudos about $750.00 for these parts and I already had the other filter. Nissan wanted over $950.00 for the bits needed. Im asking $550 ono and im able to post it if needed.
  • Nope 1
498 is for just for the timing belt and water pump kit. The items i have listed beneath were all ontop of the 498 price.
Genuine Nissan Timing Belt Stud Kit <LI>Genuine Nissan Cam Cover Gasket Set <LI>Genuine Nissan Ancillary Drive Belt Set <LI>1 Trust/Greddy Oil filter + 1 Ryco filter I have here <LI>1 tube of gasket maker stuff.
  • Like 1
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
