Hey guys, my R32 has had an R33 RB25DET in it for about 4 months, and everything has been great. However, whilst driving last week, the low oil light suddenly came on. Naturally I checked the oil level straight away, and it was fine. When I first noticed it, the oil pressure gauge was reading where it always would too. When you first start the car, it’s off, but give it 5 minutes and it comes on - and from there won’t go off. My mechanic removed the sensor and cleaned it, but this did not fix it - they were flat out, squeezed me in to replace the rear HICAS arms, but you get the idea. Below is a picture of the gauge, with precisely what happens. The oil pressure gauge appears to work fine still - it moves between about 3.5 and 5kg depending on the way it’s driven. Now what I can't for the life of me remember, is if there is just the oil pressure sender, or an oil pressure sender, AND an oil pressure switch. If it’s the latter, I guess I should replace that switch, but if there is only one, could it be a cluster issue perhaps? Some people would say just leave it, but I’m not keen on getting accustomed with warning lights on my dash, because I may miss one which shouldn’t be ignored. I am planning on running an aftermarket gauge, but I'd rather fix these issues as they come. Any help would be greatly appreciated :)
https://www.sau.com.au/forums/topic/350537-r32-rb25det-low-oil-light/
Okay so I drove the car tonight, gave it a hell of a beating (I live in the country) and it didnt flash on, even once, never lone staying on permanently. Weird. First time it hasnt been on in days...
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
