[Sa] R32 Gts-T With R33 Engine And Gearbox
Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
By Bireley_32 · Posted
Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
