Link to the thread: http://www.westcoastcruisers.com.au/Forums/topic/1261-wcc-poker-run-2/page__view__findpost__p__14845
Date: Sunday the 30th of January.
Meet Point: Powis St Car Park, Lake Monger Reserve.
Time: 09:30 for a 10:00 departure.
Map: Poker In The Rear.
As usual, there's a $10.00 entry fee per person (not per vehicle), and the more the merrier so bring yer mum.
The rules will be exactly the same as the last poker run and I'll cut and paste them below:
What is it?
The Poker run is a cruise with 5 stops, including the meet point and end point.
At each stop, players will select a card from the deck. The card will be noted and the player will initial their selection on an entry sheet. The card will then be returned to the play deck. The deck will be shuffled and the next player will draw a card, with the process repeating until all players have selected their card at that stop.
At the next stop, all players will select from the deck again. If a card is drawn that a player has previously selected, that card will be set aside and another selected until one is drawn that the player has not yet added to his/her hand. Once the selection is complete, the card that was set aside will be returned to the deck, the deck shuffled and the next player will draw.
The process repeats until the end point.
At the end point, the player with the best hand will be deemed the winner and will win the pot.
Split pots do occur occasionally where the winnings are divided among the players with the best equal hand.
What is the cost?
The cost of entry will be $10.00, payable on the day.
Any amount of people can play so passengers are encouraged to participate in order to increase the pot value. 10 players = $100.00, 50 players = $500.00, 100 players = $1000.00. Not a bad day out at all.
We will not restrict the organisers from participating as the cards are drawn in the presence of others and will be handled by a third party when the organisers draw for the sake of fairness.
What are the winning hands?
The hands in order of importance are as follows:
1: Royal Flush - A hand that contains five cards in sequence, all of the same suit to the ace. Eg: 10/J/Q/K/A all spades.
2: Straight Flush - A hand that contains five cards in sequence, all of the same suit. Eg: 2/3/4/5/6 all clubs.
3: Four Of A Kind - A hand that contains four cards of one rank, and an unmatched card of another rank. Eg: 2/2/2/2/9.
4: Full House - A hand that contains three matching cards of one rank, and two matching cards of another rank. Eg: 9/9/9/3/3.
5: Flush - A hand where all five cards are of the same suit. Eg: 2/4/8/10/K all hearts.
6: Straight - A hand that contains five cards of sequential rank. Eg: 7/8/9/10/J.
7: Three Of A Kind - A hand that contains three cards of the same rank, plus two unmatched cards. Eg: 7/7/7/Q/A.
8: Two Pair - A hand that contains two cards of the same rank, plus two cards of another rank (that match each other but not the first pair), plus one unmatched card. Eg: 5/5/K/K/7.
9: One Pair - A hand that contains two cards of the same rank, plus three other unmatched cards. Eg: 9/9/3/6/J.
10: High Card - A hand in which no two cards have the same rank, the five cards are not in sequence, and the five cards are not all the same suit. Eg: A/3/7/J/Q.
There are 311,875,200 ways of being dealt five cards from a 52 card deck, so the chances of two people ending up with the same hand are highly improbable.
There will be a few poker players among the participants so deciding the best hand will be verified.
https://www.sau.com.au/forums/topic/350566-west-coast-cruisers-poker-run-2/
Sorry to say guys that this cruise will be postponed due to the weather that will be with us on the day. All of the stops and meet points are out in the open so it will be impossible to enjoy the outdoors.
I will reannounce the new date and time soon.
  • 1 month later...
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
