I've been thinking about fuel for my rb30. I was going to go e85 but we can't get it at the pumps where I'm at. I was going to ship it by the barrel, fill up for races(time attack, drag, HPDE, etc), and use pump gas for the street.
BUT! If I'm going to be shipping fuel and making an alcohol safe fuel system, why not use methanol? According to my math, even at 75/25 meth-to-pump it should make more power than E85. It should also run cooler, be easier to find (lots of drag cars here,) and be cheaper.
Anybody gone done this road before?
Interesting fact- in china, where corn is expensive, flex fuel vehicles run M85!
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/
Nobody has any experience? I keep looking around and all I'm finding is a lot of bs about methanol being dangerous and toxic. It's actually less dangerous and toxic than gasoline.
I think the only reason it isn't used is because Injectors large enough to use methanol and still idle and run normal only recently became available. (id2000)
Unless someone has a good reason not to do it I'm gonna give it a shot.
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5630372
I can add that buying E85 at the pump will only give many inconsistent results.
Preferred race fuel is C16 or Aviation fuels as they prove to be more stable throughout the year.
As for Power, Methanol makes a bigger bang but more costly to obtain. You will require some form of license in most developed countries.
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5630563
What is the engine built for? Compression, expected boost, is it intercooled, what is the injector location?
Edited by rob82
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5630810
Pump e85 is fine provided you tune for the variations. We can match c16 but @ $1 a litre....
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5630944
If you are talking about E85 vs meth, why not go WMI? You get pretty much the same power boost as you would when tuning for E85 and the methanol cooler running = the best of both worlds. And you won't use much unless you are boosting, don't need huge injectors, can run on pump fuel everywhere, don't need to upgrade any fuel lines or systems and there are some great packages out there for it. Plus you can vary the amount of meth by juggling with nozzle sizes and multiple nozzles. It is on tap just waiting for you to boost it!
As an example I used probably 100-150ml in 400km of highway driving and I have a 3.5 litre reservoir. I know that when you race with it it is used heaps more, but you can top up between laps etc.
And mixed 50/50 WM in a container is pretty much inert.
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5631965
One bad thing I've seen with methanol is it burns with almost invisible flames, though E85 could be the same.
All those burnout cars that run it seem to set their tyres and half the track alight though. I also saw an evo with big cams shooting 1m flames on the overrun after it supposedly had been tuned, whether this was the car or the fuel I do not know.
Anyone know more ?
Edited by Rolls
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5633915
Anyone know more ?
The 15% fuel in the methanol would cause the flame to be visible :)
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5633942
BoostedR's build data from the -5 vs GTRS thread
I have built a RB31/26DETT 824hp -engine hp
264 9.8 HKS
Tomei Dumps
3" x 2 (no mufflers)
530ft lb @ 2800rpm
22psi max
Garrett -10's
Ported std manifolds
BP98 with 10% methanol
Motec
That result proves you can lean on the engine a lot more with just 10% methanol. A water/meth injection setup would produce a similar result.
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5633983
I have an aquamist hfs-6 on the car right now. It works good but won't give the same performance as mixing meth. It's also something else to break at the track.
The 15% gasoline is supposed to add color to the flame also. I might try a 50/50 mix and move up from there.
https://www.sau.com.au/forums/topic/350574-methanol-vs-e85/#findComment-5634225
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
