Hi guys,
Ive been thinking about possibly switching over to a sequential gearbox for my car. I know of GETDRAG and Hollinger but is there anything else out there? A Hollinger is way out of my budget but i hear the GETDRAG ones can be had for under 5k?
Where can one find more information about these products? does anyone down in Melbourne have one for a possible test?
Apart from being very noisy both in 1st gear, reverse and low revs, What else can one expect out of these types of gearboxes?
cheers
https://www.sau.com.au/forums/topic/350597-sequential-gearboxes-for-er34/
dunno what a GETDRAG gearbox is, but something tells me you're talking about a Getrag, they don't just make sequentials only either, they R34 GTR and Poopra both came with factory Getrag gearboxes.
something tells me what you're after is something like this:
http://www.nengun.com/ikeya-formula/sequential-shifter
in action:
converts your H pattern to "sequential".
http://www.nengun.co...uential-shifter
in action:
I just realized that this still needs clutch activation to operate. Ideally id like to convert to a sequential transmission rather then a H box converter....if you know what i mean.
A true sequential gearbox is 5 figures, bit ridiculous for a street car.
Stock gearboxes are more than adequate for the power you are making, so unless you have 15k or so to burn, there really isn't much point especially considering you still need to use the clutch.
5 figures huh? i was hoping to be under the 5k mark.
Off the line launches are somtimes very difficult in a MT. Ive invested alot of money into suspension and tyres but it only does so much. Its also sometimes very frustrating at how much speed is lost during shifts. You can only shift so fast in a MT, and yes im using a short shifter as well. Recently sat in a 3-speed auto making close to 580hp. Its ridiculous how fast these transmission allow the car to move.
Say what you want, i may not be a master at shifting but AT will always be quicker then MT.
Edited by Jap_Muscle
Ah no, Seq boxes are expensive, just how it is.
Ye it only does so much as its predominately down to the driver controlling it.
When I was racing @ Calder regularly I could manage 1.9-2.0 60ft's with 225 street tyres on there. It's not just a case of the tree goes green and you plan the foot to the floor.
Either that or get a better set-up that will stage/control boost and feed it in.
Also a short shifter I found, made my shifts slower.
You also have to factor in a rebuild of the dog rings and other components in a sequential shifted box every 5,000 k's or so as well, this is usually in the 2~3,000 range.
If you're setting that thing up for drags, look at putting in a really good auto and torque converter combination. Sequential is pointless unless you're hitting the track.
If you want to do clutchless manual on a "budget", get a straight cut dog engagement gearset. You'll still have to practice your launches but your shifts won't be a great deal worse than an auto.
Getrag also has to be the most misspelled and mispronounced name in the history of gearbox manufacturers lol.
sif. Porsche 911's doppelkupplungsgetriebe gearbox was concieved by the germans to fuck with the allies.
You're thinking of the entire German language...that's right, they pre-empted WW2 with antero-mindf**king.
Ever played Tales of Valor as the panzer elite? That'll leave you doppeled.
    • I transferred from full time service to Army Reserve, so I still have access, work has been super keen to get me in to work in the OPS realm, so just turning up to use the gym......and ovens, isn't causing any issues, apart from me needing to keep on telling them that I won't be doing any reserve days until I get my joint in Goulburn sorted  Basically I can now work whenever I want, for how long I want now, and it's all tax free Next time we have some fires or floods you might see me covered in mud, or cutting sick in some plant equipment cleaning up, the Reserves love getting in the news, LOL
    • Final finish outcome of 80°c was typical to the pics, I've turned the oven down to 50°c and will pick them up after the gym tomorrow  The before and after difference was amazing, the wrinkle paint has covered all of the casting marks completely It did take a couple of hours to key it all and get in all of the crevices, but, for me it was time well spent for the final outcome, but I have all the time in the world to do it at the moment  Ended up with 4 coats, each sprayed at different angles to get optimal coverage and thickness As for the fixtures and intake box thingo that hasn't made it, the supplier is apparently posting the fixtures, and, are now sending a different CAI that is in stock The replacement CAI is actually better than what I originally ordered, but will require a pod filter that locates under the front bar, still serviceable, but it basically removes the whole OEM filter box and ducts into the front bar, so filter cleaning will require ramps and the removal of some front bar undertray, not a war stopper, just some ramps and an additional 10 minutes work every few months From looking at it it is made from alloy pipe from the throttle body, through the CAI hole in the rad support, then right turning under the bar, luckily the wrinkle paint was on special and I got 2 cans for $30ish, so the alloy will get the same wrinkle treatment as the intake manifold, hopefully it turns up soon, either way, the car will be getting booked in soon, if the parts aren't here, I'll just get MX5 Mania to " make it work"
    • I'm so glad base security is so high. I see they stopped some random codger from being able to just wander in off the street... 😛   PS, intake looks good!
    • So far so good, another hour and their done
    • Exactly how each part works and how they all work together to make the engine function. That's all I'd need to do a basic build. Maybe how forced induction works. I probably need to learn some of the maths behind it all as well.
