Yeah, money is no problem is just the booking in and waiting etc I suppose ill have to if i cant track it down.
No one thinks gasket ?
an exhaust leak post turbo would just make it noisy, pre turbo would also be noisy but could cause boost to drop, neither would make it run rich or misfire though
  • Replies 53
leaky injector?
never heard of them leaking into the cylinder, I guess its possible though.
other thing to check is if you have a rising rate regulator that the lines haven't fallen off, however that would probably make it lean I think, not rich.
Edited by Rolls
Are they all covered exaclty the same? If so that rules out a leaky injector.
Then u need to do a pressure or smoke test on the entire intake system from airflow meter to inlet manifold.
Just for a quick look if u can check on the fc hand controller in settings and airflow make sure its still set on ur current airflow meter. If theyre stock then it should be on stock. If z32 then on vg30 etc. Its an easy thing to accidently change and sometimes will still run but tune is waay off.
If the intake is all sealed up then the dyno is the next best bet. Give ur tuner some new plugs so he can run it up on the rollers with fresh plugs. So let him putt hem i. Just before he runs it.
It sounds like Lean pop to me, if it's only soon it as it rolls on boost, check the fuel pressure after the filter, I'd just replace the filter for the sake of it. Is the car running stock boost?
It never realy got off boost driving, it was just short bursts up and down my street, the plugs were dark but I think that was because I had that stupid fuel tank breather plugged into the TB lol. Once you found that prob, than it was missing just a's it rolled on boost, the main way I found out it was lean poping, was I turned the boost down from 16psi back to stock, and it got alot better. Hardly did it at all, that's when I realised it was lack of fuel, and a during fuel pump was to blame.
But in saying that if I would have changed the plugs after we change the TB plumbing I'd say the plugs would have gotten light coloured.
Haha oh yeah forgot u did that with the breather. I suppose thats 1 way of getting more fuel in the engine without bigger injectors. Haha just let the engine suck it from the fuel tank lol.
Lol we should do that with my gtr next time it's on the dyno.... Save me heaps of cash on injectors. Bahahaha
Yea it was sucking vapour, it was just running mega rich and backfiring when you lifted your foot. Like a big back fire lol 1 meter flames, like a gun going off. Haha it blow the middle muffler from the inside out hahaha broke all the little tac dipple welds holding it together. I learnt my lession there hahaha
All are covered the same.
I think I may have a couple of gaskets which are pretty much f**ked, ordered new ones from nissan.
Will check the intake.
more about my car, has a new fuel pump. plugs are 1500kms old(not gapped to .8), new oil. and its running a haltech so no afm and on o2 sensors!!
althought i blew a hose and covered the pods in oil and i had a few inlet hoses off the other day and saw alot of oil in there. so looks like turbo to inlet manifold pipes will have to be pulled out and cleaned out from all the oil
i was gonna check th igniter module.
i think i have a bad grounding in the engine but...
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
