Item Summary: Nissan Skyline R33 Highly Modified - RB30DET GT35R Track ready, street weapon!
Condition: Used
Reason for Selling: Not being used
Asking Price: 17500 Negotiable
Delivery Methods: PickUp
Contact Info: PM
Extra Information:
1994 Nissan R33 GTS25T
Mod List:
RB30DET Conversion Engine built by RIPS NZ
RIPS Custom Plenum http://www.ripsltd.com/index2.html
High mount Custom GT35R TO4Z Compressor Wheel, Surge Ported 0.5 AR Compressor Cover .82 Rear housing was built by Chris at MTQ Qld
Tial 50mm Blow off Valve
JJR 100mm GTR Intercooler
NPC big mouth track clutch with billet flywheel
Link G4 Plugin ECU with MAP Sensor XS Loom and Boost control Solenoid - Launch control antilag etc http://www.linkecu.com/products/engine-man...g4-plug-in-ecus
Siemans 575cc Injectors
Bosch 044 Fuel pump and ARE surge tank setup in boot
Custom Dump into 3.25" Kakimoto Exhaust
Bilstien "Sydney Kid" shocks
Eibach Springs fitted + King Springs as spares
RDA Slotted Rotors
Bendex Ultimate pads
17" Work VS XX 3 piece mesh rims in white 8.5" / 9.5" wrapped in pretty shot Kumho KU36's
18" Racing Sparco 5 spoke 9" / 10"
Both complete sets of wheels and lug nuts included in sale
Series III GTR Xenon Headlights
Drift Lip
Standard Skits M-Spec Pods
Standard M-Spec bar with very rare Nismo lip + Freshly painted unfitted GTR Front Bar Both included in sale
Nardi Steering wheel
Boost / Exh Temp / Oil Temp Gauges
Alpine CDA9855 top of the line Head unit with ipod link
Unsure of the speakers but they are decent SQ they were in it when I purchased car
Drivers window switches are looking a bit second hand
All seats are in perfect condition - NO rip in drivers seat!
Carpet / Hood lining in good condition
Rare Genuine Nissan / Nismo floor mats I sourced from Japan in good condition
Trust Shift knob fitted + New Nismo Titanium Shift Knob included in sale
Paint work is in immaculate super glossy condition! there is a car park dint in the drivers door the stock front bar has some scrapes and there is a small scratch about an inch long on the rear bar
I have kept the paint detailed with a mixture of Bowdens own, Auto Glym and 3M products for the last 4 years and it really shows.
Rego is till September 2011
Air conditioning is not cold so needs to be re-gassed
Power steering has a slight leek in one hose but can ensure it is fixed before sale
Thats about all I can think of for the moment :)
A boot full of stock bits and odds and ends included haha
Pics of the car are here: http://www.boostcruising.com/forums/index.php?showtopic=682018&st=0&p=1286860885entry1286860885
https://www.sau.com.au/forums/topic/350690-nissan-skyline-r33-highly-modified/
Has not been out of the garage for 2 weeks :( pretty much the reason for the need to sell... Detailed the interior looking good for any inspections!!!
  • 4 weeks later...
  • 1 month later...
Love the front lip on this car, I just have to say, make a mould and sell them! When I get my r33 I would most certainly be after one! If i had the money I would take it off you, but unfortunately, I dont :D
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
