Engine:
What are the specifications of the RB series engine?
Nissan makes engine identification easy
all those letters and numbers have meanings!
RB series of engine
20 / 25 / 26 capacity (20~1998cc / 25~2497cc / 26~2597cc)
D Double Overhead Cam (or DOHC)
E EFI (Electronic fuel injection)
T /TT Turbo / twin turbo
RB20E 97kw@5600rpm 172Nm@4400rpm
RB20DE 116kw@6400rpm 184Nm@5200rpm
RB20DET (Red top) 134kw@5600rpm 225Nm@4400rpm
RB20DET (Silver top) 160kw@6400rpm 263Nm@3200rpm
RB25DE 142kw@6400rpm 231Nm@4800rpm
RB25DET 187kw@6400rpm 295Nm@4800rpm
RB26DETT 208kw@6800rpm 368Nm@4400rpm
Basic R32 specifications:
2 Door Specification 4 Door Specification
Front Track 1460 mm
Rear Track 1460 mm
Length 4530 mm
Width 1695 mm
Height 1325 mm
Ground Clearance 145 mm
Fuel Tank 60 litres
Front Track 1460 mm
Rear Track 1460 mm
Length 4580 mm
Width 1695 mm
Height 1340 mm
Fuel Tank 60 litres
Vehicle weights
R32 GTS 1260 kg
R32 GTS25 1380 kg
R32 GTSt 1280 kg
R32 GTS4 1480 kg
R32 GTR 1480 kg
R33 GTS25T sedan 1398 kg
NB: these weights are unconfirmed.
R32 Wheels
R32's are available with the following factory wheels:
Size Offset OEM tyres
14x5 1/2 JJ 40 mm offset
165SR14
185/70R14
15x6 JJ 40 mm offset
185/70R14
205/60R15
16x6 1/2 JJ 40 mm offset 205/55R16
16x8 JJ 30 mm offset 225/50R16
The 16x8 JJ are GT-R wheels are very hard to come by. The size of the wheel is stamped into
the rim for identification purposes.
Upgrades to tyre size can be done with differing results. Some members have reported good
results with 225 sized tyres on the GTS-t 16x6 rim, others have had excessive tire-wall
flexing.
https://www.sau.com.au/forums/topic/35072-skyline-engine-specs/
  • 3 years later...
Some specs on the RB20DET..
Thanks,
Abu
Engine type: RB20DET
Displacement (cc): 1998
Combustion chamber: Pent-Roof Type
Valve arrangement: DOHC Belt Drive
Bore x stroke mm: 78.0 x 69.7
Compression ratio: 8.5
Compression pressure: (kg / cm2) / (RPM) 12.0 / 300
maximum output (net) (ps / rpm): 215 / 6400
maximum torque (net) (kg-m / rpm): 27.0 / 3200
Fuel consumption ratio (g / GS.h) / (rpm): 215 / 2400
Dimensions m/t (l / w / h) (mm): 845x660x685
Dimensions a/t (l / w / h) (mm): 830x660x685
Idle speed (rpm): 800
Ignition timing a/t (BTDCdegrees / rpm): 15 / 650
Ignition timing m/t (BTDCdegrees / rpm): 20 / 650
Firing order: 1-5-3-6-2-4
Valve clearance cold (mm) intake: 0.45 +/- 0.003
Valve clearance cold (mm) exhaust: 0.38 +/- 0.003
Throttle chamber bolts torque setting (kg-m) first stage: 0.9 - 1.1
Throttle chamber bolts torque setting (kg-m) second stage: 1.8 - 2.2
Flywheel run-out limit (mm): 0.1
Con rod nut tightening stage 1 (kg-m): 2.3 - 2.9
Con rod nut tightening stage 2(kg-m): 3.9 - 4.5
Max Powe (KW/BHP): 160/214 @ 6400 RPM
Max Torque (NM/ft-lbs:) 263/194 @ 3200 RPM
Redline: 7600 RPM
Edited by abu
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
