Engine:
What are the specifications of the RB series engine?
Nissan makes engine identification easy
all those letters and numbers have meanings!
RB series of engine
20 / 25 / 26 capacity (20~1998cc / 25~2497cc / 26~2597cc)
D Double Overhead Cam (or DOHC)
E EFI (Electronic fuel injection)
T /TT Turbo / twin turbo
RB20E 97kw@5600rpm 172Nm@4400rpm
RB20DE 116kw@6400rpm 184Nm@5200rpm
RB20DET (Red top) 134kw@5600rpm 225Nm@4400rpm
RB20DET (Silver top) 160kw@6400rpm 263Nm@3200rpm
RB25DE 142kw@6400rpm 231Nm@4800rpm
RB25DET 187kw@6400rpm 295Nm@4800rpm
RB26DETT 208kw@6800rpm 368Nm@4400rpm
Basic R32 specifications:
2 Door Specification 4 Door Specification
Front Track 1460 mm
Rear Track 1460 mm
Length 4530 mm
Width 1695 mm
Height 1325 mm
Ground Clearance 145 mm
Fuel Tank 60 litres
Front Track 1460 mm
Rear Track 1460 mm
Length 4580 mm
Width 1695 mm
Height 1340 mm
Fuel Tank 60 litres
Vehicle weights
R32 GTS 1260 kg
R32 GTS25 1380 kg
R32 GTSt 1280 kg
R32 GTS4 1480 kg
R32 GTR 1480 kg
R33 GTS25T sedan 1398 kg
NB: these weights are unconfirmed.
R32 Wheels
R32's are available with the following factory wheels:
Size Offset OEM tyres
14x5 1/2 JJ 40 mm offset
165SR14
185/70R14
15x6 JJ 40 mm offset
185/70R14
205/60R15
16x6 1/2 JJ 40 mm offset 205/55R16
16x8 JJ 30 mm offset 225/50R16
The 16x8 JJ are GT-R wheels are very hard to come by. The size of the wheel is stamped into
the rim for identification purposes.
Upgrades to tyre size can be done with differing results. Some members have reported good
results with 225 sized tyres on the GTS-t 16x6 rim, others have had excessive tire-wall
flexing.
https://www.sau.com.au/forums/topic/35072-skyline-engine-specs/
  • 3 years later...
Some specs on the RB20DET..
Thanks,
Abu
Engine type: RB20DET
Displacement (cc): 1998
Combustion chamber: Pent-Roof Type
Valve arrangement: DOHC Belt Drive
Bore x stroke mm: 78.0 x 69.7
Compression ratio: 8.5
Compression pressure: (kg / cm2) / (RPM) 12.0 / 300
maximum output (net) (ps / rpm): 215 / 6400
maximum torque (net) (kg-m / rpm): 27.0 / 3200
Fuel consumption ratio (g / GS.h) / (rpm): 215 / 2400
Dimensions m/t (l / w / h) (mm): 845x660x685
Dimensions a/t (l / w / h) (mm): 830x660x685
Idle speed (rpm): 800
Ignition timing a/t (BTDCdegrees / rpm): 15 / 650
Ignition timing m/t (BTDCdegrees / rpm): 20 / 650
Firing order: 1-5-3-6-2-4
Valve clearance cold (mm) intake: 0.45 +/- 0.003
Valve clearance cold (mm) exhaust: 0.38 +/- 0.003
Throttle chamber bolts torque setting (kg-m) first stage: 0.9 - 1.1
Throttle chamber bolts torque setting (kg-m) second stage: 1.8 - 2.2
Flywheel run-out limit (mm): 0.1
Con rod nut tightening stage 1 (kg-m): 2.3 - 2.9
Con rod nut tightening stage 2(kg-m): 3.9 - 4.5
Max Powe (KW/BHP): 160/214 @ 6400 RPM
Max Torque (NM/ft-lbs:) 263/194 @ 3200 RPM
Redline: 7600 RPM
Edited by abu
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
