make:nissan R31 skyline
colour:red
Modifications:
FULL FORGED INTERNALS.
GARRETtgt35 /40 turbo.
custom ASE intercooler and manifold piping.with steam pipe exhaust manifold,custom. custom dump pipe.
50mm turbosmart progate with screamer pipe.
bosch 700 hp fuel pump.
surgetank.
14mm rb30 fuel rail.
60lb siemens deka injectors.
trust greddy blow off type rs.
PLAZMAMAN intake plenum and throttle body.
CP pistons with rings pins and pinlocks.
ARP head and main stud sets.
ACL race bearings,rods and mains.
ACL race series gasket.
Spool rod set.
Reground JPC camshaft,new heavy duty valve springs and retainers.
Crankshaft oil pump drive sleeve,GTR upgraded oil pump drive gear set.
Vi-Pec ECU.
Extreme carbon twin plate clutch and flywheel kit.
Ross tuffbond race metal jacket balancer.
full engine machined and balanced.
geniune nissan flywheel bolts.
new injector plug kit.
gates raciing timing belt with tensioner.
new water pump, geniune nissan.
battery moved to rear.
hi/ low boost map settings.
new radiator.
racing logic coilovers 32 point full adj.
custom hats to suit r31 for coilovers.
r33 gtr genuine nissan oil pump.
R33 RB25DET 5 speed.
mini spall diff.
custom sump with wings and internal baffles.
Custom ICE ignition kit with spark amplifier.
NEW GM / NISSAN crank angle sensor.
NEW single peice tailshaft.
turbo beani.
FRONT BRAKE LINE LOCKER.
NEW disc rotors.
custom adj control arms for rear with heim joints tubular steel.
engine bay strut.rear strut.
upgraded swaybars whiteline racing.
r33 gtr front brakes.
custom straight through 3inch exhaust.
MAKING 352RWKW.
much more cant be f*kd writing all..........................
Price $18500
Phone: matt on 0406061168
im advertising for my mate as he doesnt have internet.
https://www.sau.com.au/forums/topic/350736-sa-r31-4-door-worked/
