Ten tips to a good day
1.)Oil level is at the Max mark on the dip-stick
2.) Coolant - ensure the overflow/reservoir is full
3.) Brake Fluid - ensure the fluid is at the Max marking in the reservoir
4.) Clutch Fluid - ensure the fluid is at the Max marking in the reservoir
5.) Check that all pipe-work is secure and no hoses are becoming loose
6.) Check that your battery is secure and does not move
7.) Make sure that all caps are on and secure
8.) Suitable material left on your brake pads
9.) Tyres are in good condition and wheel nuts tight
10) Nut behind steering wheel secure
9 out of 10 aint bad
See you all tomorrow guys and girls
1 1/2 ltrs of oils in the can 2 1/2 ltrs in-on-around-under the car with god knows how much I dropped on the track.
First lap was slow as they left the red light on most the way then when it was turned off I gassed it to the last turn braked then mashed it down the straight, slow into 1-exit 2 and headed up to 3 with the arse slipping around which I put down to cold tyres, went around again with the arse playing silly buggers then at the exit of 2 heading to 3 it tanked slapped me around a bit and I went off, I got back on allright but it done it again in the exact same spot AND I lost powersteering so I came into the pits to see WTF was up.
Popped bonnet and the cold side was covered with oil and both the powersteering and aircon belts were off, on further inspection the aircon belt was torn to peices and wrapped around the fan with little bits everywhere while the P/S one had its arse handed to it but not as bad(had alot of the cord ripped out).
Oil came from the catch can which is where I got the 1 1/2 ltrs (volume of the can) from.
Filled up the car with 4ltrs of oil (sump holds about 7), moved the bits of eaten belts and came home.
All in the first 3 laps.........................................................:rant:
Mark
The oil sprayed onto the belts causing them to slip off. Let us know what they do about ur engine.
Had a great day today. Few bingles at the end of the day unfortunately. No body hurt luckily.
Time for me to get some decent tyres on the front to get rid of the oversteer and hopefully my wilwood brakes turn up this week. My brakes were a big let down.
yeah thanks people it was ace, no injuries to my pride other than a flat spotted tyre and the odd backwards moment into the dirt.
i wish some other people (Eric) could say the same..poor bugger, keep us posted on devs and if you end up getting any kind of recompense from the offender.
managed a personal best of 1.15.8 so pretty chuffed with that though i know theres lots mores in it!
bring on the next track day ASAP!
pics etc up after i pass out..
Forgot to say I have some pics on my facebook, not sure if you can see this, if not feel free to add me! http://www.facebook.com/album.php?aid=272781&id=652446637&l=04a9065e42
And also MASSIVE thanks to Steveo for standing there all day on pit lane, and to AggroDave for sorting out all the entries and forms and shit. You guys rock for the time you put in!
Guest
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
