what about a full Cometic multi layered steel gasket set.
Full set for intake, exhaust, head etc. Cometic Street Pro - http://cgi.ebay.com/ebaymotors/Cometic-Street-Pro-Top-End-Gasket-Kit-R33-RB25-RB25DET-_W0QQcmdZViewItemQQhashZitem3efbaa0556QQitemZ270510196054QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
no issues then running 18psi, right in the turbo nice-zone :)
same injectors, similar mods, gt3076r IW, chip+piggyback, 250kw@wheels (auto awd)
really an 040 isnt big enough???
mines flowing enough to feed 550cc injectors without a fuel reg or rail pressure bump and Im sure Ive read it can supply larger injectors too.
A fuel pump flows more fuel at a lower fuel pressure. Increasing the fuel pressure above standard will only make the fuel pump run out of flow quicker.
I would put a factory airbox on it with a panel filter.
So you already have the 4bolt dump pipe? That is handy!
Injectors: From my car I can extrapolate that if you want to run 11.5:1 on standard pressure then you'll only get ~250rwkw. If you bump up the pressure a tad and are willing to run to 90% duty then you'll get a bit more, perhaps 280rwkw. So they are borderline, but SHOULD be just enough. They are 450cc btw and allow a lovely idle.
Tune at 1.1bar and be happy - get a hand controller to self adjust the part throttle.
Then buy tyres in bulk.
I disagree with the factory airbox, you will loose a signifant amount of power. Its criminal on a 3076 imo. If you are certain on keeping the factory airbox then at least upgrade the intake piping to 3" metal. Someone on here had one made up and it was quite expensive as it must join the airbox at exactly the right location.
You will gain power with a 3" metal intake and pod (preferably shielded) when above 250rwkw.
See the quoted post above regarding those small injectors. It is criminal using such small injectors on a 3076 turbo, it will limit you. Otherwise, get a smaller turbo. No point having a large turbo running low boost and relatively low power.
Sell your current injectors and upgrade to larger ones, shouldnt be more than a few hundred changeover and then you will never have to worry about it again. You can then allow your turbo to do its thing, even run E85, or up the boost if you do an engine build one day etc etc. Not to mention it is safer to run injectors less than 80% duty cycle. Sell you fuel pressure regulator and put it towards the injector upgrade instead.
I would have to recommend getting at least 600cc injectors if you want to run pump fuel
and larger again if you wish to run E85 as others above have said and you shouldn't have
any trouble with larger injectors with a good tuner. have a look at deatchwerks in america
for larger injectors especially with the current exchange rate.
Whats your radiator like? A Gtst running 300kw makes a bit of heat esp. on a hot day. I'd get it serviced and cleaned [or new whatever you decide]. I'd even consider an oil cooler kit as well.
And you will want a boost controller, a dual solenoid one is the ducks guts.
But your setup is the basis for a lot of fun............
^^^ not essential at the very minute but top recommendation in future.
I would replace your 'cooler core mate, dont worry about the plenum. Browse the ForSale stuff for a Jap-brand second-hand one.
+1 for PFC hand controller!
