2010 Motive Gt-R Challenge
No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
Disconnecting rods! must have been an unpleasant surprise...
By drifter17a · Posted
So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR -
So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want? here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a> https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q -
Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway. Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
