Hi guys,
I live in Sydney & want to know if anyone knows of who can remove my front & rear window from my r32gtr shell?
I guess i could call o’brien glass – is there anyone else though as im sure they wont be cheap...
Alternatively – i am tempted to do this myself as well if anyone can point me in the right direction.
regards
https://www.sau.com.au/forums/topic/350820-any-window-removers-in-sydney/
stevo - the thread you closed was directed at 'can i remove the windows myself' whereas this thread is 'who in sydney can remove my windows'...although i do also ask in this thread whether i give it a crack myself - nonetheless i understand the confusion :)
back on topic
I have removed a rear before , i used this tool
I got it from a windcreen supply warehouse for about 35$.its basically just a handle with a bent blade on it and another handle to help you drag it along, you could make one if your clever enough..
Im not sure if windscreen places like obriens would sell them but if you find the people that supply there windscreens they should have them..
Its a prick of a job but if you keep the blade clean and sharp it csan be done with patience
There is a wire that runs around the rubber and apparently if you hook it up to a battery and heat it it soften the rubber, though i have never tried this way the wire does exsist good luck finding the ends though..
But basically you just have to be really gentle and cut your way through the rubber ,i think I did use a hairdryer to soften it a bit as well. Heat, slice, heat, slice And make sure you dont twist the screen by pulling on one corner or something you have to keep it flat,lay down in the car and push it with your feet gently if you can once the rubber is cut away..It will test your patience..GL..
Edited by Arthur T3
i got a quote for $90 to get the rear window which is toughened so the glass expert said this wont crack, however, as the front windscreen is laminated there is a 50% chance of it cracking which sux
if they cant get the front out every time without fail they should give up and look for another job
I'm thinking that this is a bit of a tough call... a glass company can't really say for certain the strength of of the forward facing window of a 20 odd year old vehicle which probably has seen it's far share of stones and other crap thrown at it.
I replaced the rear window on my old R31 once, granted it was already shattered so the removal process was simply to break the glass further and clean the area around the window so we could stick the replacement in... tools used where a hammer, a chisel and a screwdriver :)
if the window is in good nick there shouldn't be a problem getting it out with out cracking it
i dont give a shit about excuses, if you're a window guy thats your job and if you can pull a front screen without breaking it you need to find a new job
im sick and tired of the "all care but no responsibility" bullshit they all try and spin
i had an absolute dead shit from obriens smash both my rear quarter windows on my skyline the first time i painted it
so thats $550 each window plus the money he wanted to pull em out
i told him where he could stick his money cause he didnt do the job so i wasnt paying him
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
