Hi guys,
I live in Sydney & want to know if anyone knows of who can remove my front & rear window from my r32gtr shell?
I guess i could call o’brien glass – is there anyone else though as im sure they wont be cheap...
Alternatively – i am tempted to do this myself as well if anyone can point me in the right direction.
regards
https://www.sau.com.au/forums/topic/350820-any-window-removers-in-sydney/
stevo - the thread you closed was directed at 'can i remove the windows myself' whereas this thread is 'who in sydney can remove my windows'...although i do also ask in this thread whether i give it a crack myself - nonetheless i understand the confusion :)
back on topic
I have removed a rear before , i used this tool
I got it from a windcreen supply warehouse for about 35$.its basically just a handle with a bent blade on it and another handle to help you drag it along, you could make one if your clever enough..
Im not sure if windscreen places like obriens would sell them but if you find the people that supply there windscreens they should have them..
Its a prick of a job but if you keep the blade clean and sharp it csan be done with patience
There is a wire that runs around the rubber and apparently if you hook it up to a battery and heat it it soften the rubber, though i have never tried this way the wire does exsist good luck finding the ends though..
But basically you just have to be really gentle and cut your way through the rubber ,i think I did use a hairdryer to soften it a bit as well. Heat, slice, heat, slice And make sure you dont twist the screen by pulling on one corner or something you have to keep it flat,lay down in the car and push it with your feet gently if you can once the rubber is cut away..It will test your patience..GL..
Edited by Arthur T3
i got a quote for $90 to get the rear window which is toughened so the glass expert said this wont crack, however, as the front windscreen is laminated there is a 50% chance of it cracking which sux
  On 18/01/2011 at 11:53 AM, Dahtone Racing said:
if they cant get the front out every time without fail they should give up and look for another job
I'm thinking that this is a bit of a tough call... a glass company can't really say for certain the strength of of the forward facing window of a 20 odd year old vehicle which probably has seen it's far share of stones and other crap thrown at it.
I replaced the rear window on my old R31 once, granted it was already shattered so the removal process was simply to break the glass further and clean the area around the window so we could stick the replacement in... tools used where a hammer, a chisel and a screwdriver :)
if the window is in good nick there shouldn't be a problem getting it out with out cracking it
i dont give a shit about excuses, if you're a window guy thats your job and if you can pull a front screen without breaking it you need to find a new job
im sick and tired of the "all care but no responsibility" bullshit they all try and spin
i had an absolute dead shit from obriens smash both my rear quarter windows on my skyline the first time i painted it
so thats $550 each window plus the money he wanted to pull em out
i told him where he could stick his money cause he didnt do the job so i wasnt paying him
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
