hello people, was just wondering where the best place is to buy online parts? im mainly looking for a power fc d-jetro, ive scoured the net but cant seem to find much, with the us dollar exchange rate at the moment is there any good places in the states to buy from? hopefully you people can help me out.
Cheers
https://www.sau.com.au/forums/topic/350823-best-place-to-buy-parts-online/
I use mainly rhdjapan and have used perfectrun.jp for a few things. Can't fault either of them.
Nengun I have not used for a long long time as they used to take ages to send your order (3 months with one order), where rhdjapan is usually here in a week. I believe the business has changed hands since so things are most likely different these days.
Jesse Streeter I have also used and he was great, excellent prices.
ordered powerfc with nengun, it arrived within 5 days including a weekend (when jap postal was over weekends), no issues with delays or "not turning up"
used them for a few other things too
Yeah I have never had a problem with Nengun orders not showing up.
They always arrived just never quicker than 4 weeks for me. And I ordered hheeeeaps of stuff off them over a few years. This was back around 2007-2008.
Rhdjapan has gone out of their way to find me tiny oddball parts - very happy with them.
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
