Hi,
I have decided to get a sound system for my r34, and am in need of a few questions to be answered.
I have decided to get a full alpine setup:
INA-W900E (Headunit)
SPX-17 PRO (Front speakers)
SPR-17C (Rear speakers)
PDX-1.1000 (Amp for sub)
PDX-4.150 (Amp for speakers)
The first question is will the front speakers fit into the door without mods, and will the rears fit without mods?
The second is, will having rear speakers have much difference with this setup, or should I just stay with the stock ones?
The third question is should I get one sub or two?
And finally, when I have the aforementioned sub, will I need the two amps mentioned or just run everything on the 4 channel amp?
Thanks guys,
Jacob
https://www.sau.com.au/forums/topic/350852-help-with-sound-system-setup/
having better that stock speakers in the back will deffinately enhance your sound quality.. run all your in car speakers of the 4 channel amp.. you will need a seperate amp for sub(s) as the 4 channel amp wont have the required LPF and you will destroy them.. also one amp will do fine for 2 subs but your best bet is just buy one decent sub an still have boot space.. i made 142Db with one 12' sub and a 800wrms amp.. not running at max levels either
this is something to consider to save some dosh, alpines offer on type x
alpine au
and yes if installed by a pro it will fit, they need mdf mounts to be solid in the doors
a little dynamat type soundeadner would be advised at least in the doors
ditch the stock speakers in all cases
run the 4 channel to the 4 inside
mono block to subs
enjoy
Hi Jacob,
I used to work in the Car Audio Industry, try Ang's Audio Shop in Klemzig http://www.angs.com.au/ . He is an Alpine dealer and will be able to help you out. You should be able to find all of those products in your vehicle. Its also best to get custom MDF baffle made for the speakers in the front rather than the standard plastic ones as you have much clearing mid base as well as improved sealing the speaker enclosure (inner door).
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
