"dimple" Neodymium Magnetic Drain Plug Group Buy #3!
Hey guys
I'm going to do one more group buy for the Dimple products as there was still a few people that missed out last time and also a few people that want to get some more (including me :D).
Same deal as last time so I won't rewrite everything; just have a look in the last group buy for details:
Dimple Group Buy #2 Information
So pricing is as follows:
1 Dimple item - $35 Delivered Australia wide
2 or more items - $35 Delivered Australia wide for the first item + $30 extra for each additional item
Eg. 2 Dimple items - $65 Delivered
Eg. 3 Dimple items - $95 Delivered
I'm sure you can all understand that, it's pretty simple.
I'll do the same max limit as last time at 20 per plug and 20 for the Black Holes, but depending on how the group buy goes I may reduce the amount. However the minimum amount for the group buy to go ahead is 20 items as before.
I will keep the group buy open until the 11/02/11 but the date may change dependent on how things go (they always end up closing a lot earlier). I will than require payment within one week from the group buy closing and will transfer the money to the US.
The people that missed out in the last group buy will once again get first choice.
Please feel free to ask any questions.
Cheers guys.
Phil
SUMP PLUG BUY LIST
1. PMR33
2. PMR33
3. SOME_CS_STUDENT
4. VOLT_BITE
5. EVIL34
6. BLOODSWORD27
7. KANDIO
8. CHUCKIE
9. CHUCKIE
10. ANDYSTYLE
11. GRIND
12. 08R3308
13. HORRACE
14. SINISTA32
15. WRRR
16. BELGARION
17. BELGARION
18. STEALTH01
19. BRENDO.R32
20. ....
DIFF PLUG BUY LIST
1. ROBBO_RB180
2. VOLT_BITE
3. EVIL34
4. KANDIO
5. CHUCKIE
6. LUKAS 33
7. CHRIS32R
8. CHRIS32R
9. SINISTA32
10. SINISTA32
11. WRRR
12. WRRR
13. 89CAL
14. ....
15. ....
GEARBOX PLUG BUY LIST
1. TROZZLE
2. ROBBO_RB180
3. EVIL34
4. KANDIO
5. CHUCKIE
6. LUKAS 33
7. CHRIS32R
8. SINISTA32
9. WRRR
10. STEALTH01
11. 89CAL
BLACK HOLES BUY LIST
1. PMR33
2. TROZZLE (REPLACEMENT)
3. ROBBO_RB180
4. SOME_CS_STUDENT
5. VOLT_BITE
6. BLOODSWORD27
7. KANDIO
8. CHUCKIE
9. CHUCKIE
10. CHUCKIE
11. CHUCKIE
12. LUKAS 33
13. ANDYSTYLE
14. CHRIS32R
15. GRIND
16. GRIND
17. SINISTA32
18. WRRR
19. .....
20. .....
  • Replies 88
Hi Phil,
iam in 8 all up,
4, Black holes,
2,Sump,
1,diff,
1,Gearbox (auto)
Thanks Phil Great work again,
Cheer`s Chuckie.
I'll start sending out payment details this weekend so we can get the ball rolling. Once all payments are made i'll put the order through and by then we still might have some more people added to the list.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
