what up,im new to this game with this being my first question so i hope someone can help. Ive been told that up here in queensland, there is a certain type of wheel spacer that can be legally used, i can get my hands on a very nice and cheap pair of 18`s but i need spacers to clear the front calipers on my r33, any one know if this is true?
https://www.sau.com.au/forums/topic/35086-wheel-spacers/
I could be wrong here, but I think that the only spacers that are legal are the ones that first bolt to your hub, and then you can bolt the wheel to the new bolts on the spacer.
Soooo, the spacers that I'm talking about aren't the ones that just float on the wheel studs, but actually bolt to the hub...
Can someone confirm?
J
https://www.sau.com.au/forums/topic/35086-wheel-spacers/#findComment-701392
You can fit wider rims fine, you just need the right offset in the first place.
I am not advocating spacers -- the possibility of them sheering off scares me sh*tless. But if you want to fit some stupidly deep dishes, etc, particularly if you are buying second hand wheels, then I can understand the appeal (even though I wouldn't buy them myself) :D
LW
https://www.sau.com.au/forums/topic/35086-wheel-spacers/#findComment-714098
I'm with Duncan, wheel spacers are just a band-aid fix and you would really need to change to longer studs while you are at it. Pushing the wheels out may well improve handling on a race car but I doubt most drivers would be able to tell the difference on the street. Proper offset 18's will have no problems with clearance.
Neil.
https://www.sau.com.au/forums/topic/35086-wheel-spacers/#findComment-716043
Interesting.
The wider the track the better the handling will be, no question there.
It is illegal in aust to widen the track beyond 24mm (from memory) or close to it. This is federal law. But if the car has been engineered, its a different matter (except in SA where an engineers report means squat), as approval can be granted to waive federal law, as is the right of all transport ministers (in each state), and is usually delegated to an approved authority - safety being the main concern.
I have been told by an engineer that widening the track of a car can put excessive strain on the axles, beyond which they were designed, thus I suppose the rulings.
If you change the offset, this will have the same effect as fitting spacers. As long as you get the nut threaded properly on a spacer, how will it be different to altering the offset?
https://www.sau.com.au/forums/topic/35086-wheel-spacers/#findComment-718012
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
