Hi there guys and girls, i am currently parting out a Black 2 door R33 S2 Skyline. i have sold the engine, gear box, suspension, and brakes but most of the other gear i still have around the place. i also have parts from a S1 RB25DET which i was in the process of rebuilding, but moneys an issue, so parting it out
  • RB25DET Head (stock condition and in very good condition, comes with rocker covers and valves etc, no plenum or coil packs or exhaust manifold) $250
  • 2x RB25DET Lower portions of the intake plenum (part that bolts onto the head) $75 each
  • RB25DET alternator $60
  • RB25DET Power Steering pump with bracket $100
  • RB25DET Throttle body $50
  • Stock BOV $30
  • S1 RB25DET coil packs (working order) $100
  • 2x Apexi BOV $50 each
  • Manual Brake pedal $20
  • Manual Clutch pedal $20
  • Slave cylinder, lines and piston (that pushes on the fork) $30
  • R33 overflow bottle $20
  • Engine fuse box cover $10
  • Complete Front hubs with upper control arms $70 each (got both Rh and Lh)
  • Drivers side Rear tail light (white in colour) $60
  • Windscreen wiper motor $15
  • Passenger airbag (not deployed) with wiring $100
  • Air bag module $60
  • Stock R33 rear strut brace (silver with red SKYLINE writing) $100
  • 2x Rear Hicas units $30 each
  • RB25 engine cross member $100
  • S2 steering wheel with airbag (un deployed) gd condition $140
  • A pillar plastics (2 sets) no holes $20 each
  • HKS (J tank) inter cooler (smaller intercooler, bit of fin damage) $100 with piping
  • Apexi Radiator (with apexi radiator cap, slight fin damage) $200 ono
  • S2 glove box and surround $40
  • Rubber manual gearbox boot with steel ring $30
  • Stock front and rear sway bars $40 each
  • Passenger side mirror (white in colour) $40
  • S2 black front grill $80
  • Rear garnish - part between tail lights $50
  • RB25 12psi turbo actuator $50
  • Pod filter adapter (to put a large pod filter on) $30
  • Black drivers door handle $20
  • Space saver $50
  • Black boot lid with s2 wing $150
  • Stock R32 GTST springs (good to get off defect) $100 for all four
  • Earthing Kit (Hot Earth) $50
  • A/C Fan $100
  • S2 front guards (2x White and 1x Black) $100 each
  • S2 Front and Rear seats (perfect, apart from small hole in drivers side) $200 the lot
  • S2 Ash Tray $20
  • Drivers power window switch (no surround) $40
  • Passenger door window switch $40
  • Electric side window switch $30
  • Petrol flapper door (white) $10
  • Passenger door, with glass (black) $120
  • Rh adjustable Castor rod (unknown brand) $40
  • Rear Quarter Panels with side glass $400 a panel
  • Rear windscreen $75
  • Door seals (good condition) $20 each
  • Bonnet latch cable $20
  • Boot latch cable $20
  • Stock fuel pump $30
  • Steering column with barrel and key $75
  • Complete s2 floor carpet $50 (no holes)
  • s13 Silvia 4 stud rear hubs, rotors and brakes $100
  • All interior plastics as well
i have lots and lots of parts, so shoot me a pm and just ask or if you want pictures of anything again happy to get some for you. Happy to post at Buyers Expense Cheers Ty :thanks:
Edited by sus 32
https://www.sau.com.au/forums/topic/350873-r33-series-1-2-parts-to-clear/
Mate,
Manual Brake pedal $20<LI>Manual Clutch pedal $20<LI>Slave cylinder, lines and piston (that pushes on the fork) $30
they mine. if you got them. belive they in good condition. how much postage 4 sydney 2113. please pm
HKS front mount - Sold
1X washer bottle - Sold (one to go)
S2 Ashtray - Sold
A/C Compressor - Sold
S2 power antenna - Sold
most other parts still up for grabs!
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
