R33 Series 1 + 2 Parts To Clear
Hi there guys and girls, i am currently parting out a Black 2 door R33 S2 Skyline. i have sold the engine, gear box, suspension, and brakes but most of the other gear i still have around the place. i also have parts from a S1 RB25DET which i was in the process of rebuilding, but moneys an issue, so parting it out
  • RB25DET Head (stock condition and in very good condition, comes with rocker covers and valves etc, no plenum or coil packs or exhaust manifold) $250
  • 2x RB25DET Lower portions of the intake plenum (part that bolts onto the head) $75 each
  • RB25DET alternator $60
  • RB25DET Power Steering pump with bracket $100
  • RB25DET Throttle body $50
  • Stock BOV $30
  • S1 RB25DET coil packs (working order) $100
  • 2x Apexi BOV $50 each
  • Manual Brake pedal $20
  • Manual Clutch pedal $20
  • Slave cylinder, lines and piston (that pushes on the fork) $30
  • R33 overflow bottle $20
  • Engine fuse box cover $10
  • Complete Front hubs with upper control arms $70 each (got both Rh and Lh)
  • Drivers side Rear tail light (white in colour) $60
  • Windscreen wiper motor $15
  • Passenger airbag (not deployed) with wiring $100
  • Air bag module $60
  • Stock R33 rear strut brace (silver with red SKYLINE writing) $100
  • 2x Rear Hicas units $30 each
  • RB25 engine cross member $100
  • S2 steering wheel with airbag (un deployed) gd condition $140
  • A pillar plastics (2 sets) no holes $20 each
  • HKS (J tank) inter cooler (smaller intercooler, bit of fin damage) $100 with piping
  • Apexi Radiator (with apexi radiator cap, slight fin damage) $200 ono
  • S2 glove box and surround $40
  • Rubber manual gearbox boot with steel ring $30
  • Stock front and rear sway bars $40 each
  • Passenger side mirror (white in colour) $40
  • S2 black front grill $80
  • Rear garnish - part between tail lights $50
  • RB25 12psi turbo actuator $50
  • Pod filter adapter (to put a large pod filter on) $30
  • Black drivers door handle $20
  • Space saver $50
  • Black boot lid with s2 wing $150
  • Stock R32 GTST springs (good to get off defect) $100 for all four
  • Earthing Kit (Hot Earth) $50
  • A/C Fan $100
  • S2 front guards (2x White and 1x Black) $100 each
  • S2 Front and Rear seats (perfect, apart from small hole in drivers side) $200 the lot
  • S2 Ash Tray $20
  • Drivers power window switch (no surround) $40
  • Passenger door window switch $40
  • Electric side window switch $30
  • Petrol flapper door (white) $10
  • Passenger door, with glass (black) $120
  • Rh adjustable Castor rod (unknown brand) $40
  • Rear Quarter Panels with side glass $400 a panel
  • Rear windscreen $75
  • Door seals (good condition) $20 each
  • Bonnet latch cable $20
  • Boot latch cable $20
  • Stock fuel pump $30
  • Steering column with barrel and key $75
  • Complete s2 floor carpet $50 (no holes)
  • s13 Silvia 4 stud rear hubs, rotors and brakes $100
  • All interior plastics as well
i have lots and lots of parts, so shoot me a pm and just ask or if you want pictures of anything again happy to get some for you. Happy to post at Buyers Expense Cheers Ty :thanks:
Edited by sus 32
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
