hey guys
just replaced my o2 sensors but from what ive read, i think something maybe wrong. o2-1 reads a .8 to .9v at idle. o2-2 sits on .06v. ive given it a bit of a rev and they both move but i would think they should be the same voltage.?? i used the rb25 (NTK OZA395-E2) *2 with plug modification
https://www.sau.com.au/forums/topic/350894-o2-voltages-in-gtr/
hey guys
GTR's trim the front 3 and the rear 3 cylinders independantly so they will neverread the same while in closed loop.
I'm not sure if I would trust either's voltage output, when fully warming up at idle you should see 0.4-0.6v.. but if they are indeed working then the first 3 cylinders are running rich (assuming o2-1 is the front sensor), while the last 3 are running lean
They will only really trim once its hot and on cruise. Try bringing the revs up to 2500rpm hot and see what you get - if one goes lean and the other rich - then you have most likely wired them around the wrong way (the best check is to watch the fuel trims as you will see one go to full positive trim(25%) and the other to full negative trim(25%)). ie front 02 signal in the rear dump and rear 02 sensor in the front dump.
just give it a rev to 2500. 02-1 sits on .9 to 1 v. o2-1 sits on .08 to .09.
checked the wiring, long plug goes to back, square plug goes to front (can someone confirm this please)
wires are in correct positions(same color wires go to heaters and same to signal wire across to plugs)
where do i see the fuel trims?? had a look in the screen for o2's and couldnt see them there
just went through my pfc screens and it turns out the o2 f/b control was turned off. there is another one, 02 sensor reg. does this need to be turned on too? must be a gtr thing cause i cant find it in any manuals
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
