  • 1 month later...
  • Replies 92
Sure...
What's in the pipeline?
Nothing serious...
Bought something cheap, will be much slower than the GTR but should be good fun.
Something to keep me busy until I build the GTR track car.
Just look forward to getting back out there and having some fun, it's been a long time....
  • 2 months later...
  • 4 weeks later...
Says in the first post!
Modified Classes:
(Any of these Mods will put you into modified class)
- R Spec Tyres / Slicks under a UTQG rating of 100 tread wear (not including 100)
- A Roll Cage
- A stripped interior. Removal of rear seats only is allowed.
Guys if I want to come and do some track days with the SAU crew but don't have a skyline, what's the procedure? I have a modified B13 nissan NX which is essentially the same as an N14 pulsar. Not interested in running R-compounds, car has a nistune, factory turbo and basic engine mods - but it's FWD. Acceptable at your events? I guess it is a nissan, even if it's gay.....
G'day guys rules on a stripped interior and no cover on parcel shelf?? Yay or nay??
is any of the fuel system in the boot?
if so I think you need a barrier, else should be ok.
Join SAU, get your cams, come play!
we Have members with FWD lancers, S chassis, evo, wrx turn up.
re our championship come talk to me on the day and will work out which class you will be in.. will be either mod or std 2wd.
M
Ash that didn't answer my question if the parcel shelf has to be covered like emts said if there us fuel system is in the boot if the speaker holes etc need to be covered to create the barrier to meet the rules not to just fall into a category
I had to cover my speaker holes, I'm on a standard fuel system....damn MSCA.
If you have something other than the standard fuel system in the back I would say you will need the rear parcel sealed up.
With the standard fuel system you will get away without it most of the time.
Though mine is 'sealed' with some rubber sheeting....so...bah.
Stripped interior means you run in our mod class, but I would imagine you are running r-comp tires anyway.
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
