  • 1 month later...
  • Replies 92
Sure...
What's in the pipeline?
Nothing serious...
Bought something cheap, will be much slower than the GTR but should be good fun.
Something to keep me busy until I build the GTR track car.
Just look forward to getting back out there and having some fun, it's been a long time....
  • 2 months later...
  • 4 weeks later...
Says in the first post!
Modified Classes:
(Any of these Mods will put you into modified class)
- R Spec Tyres / Slicks under a UTQG rating of 100 tread wear (not including 100)
- A Roll Cage
- A stripped interior. Removal of rear seats only is allowed.
Guys if I want to come and do some track days with the SAU crew but don't have a skyline, what's the procedure? I have a modified B13 nissan NX which is essentially the same as an N14 pulsar. Not interested in running R-compounds, car has a nistune, factory turbo and basic engine mods - but it's FWD. Acceptable at your events? I guess it is a nissan, even if it's gay.....
G'day guys rules on a stripped interior and no cover on parcel shelf?? Yay or nay??
is any of the fuel system in the boot?
if so I think you need a barrier, else should be ok.
Join SAU, get your cams, come play!
we Have members with FWD lancers, S chassis, evo, wrx turn up.
re our championship come talk to me on the day and will work out which class you will be in.. will be either mod or std 2wd.
M
Ash that didn't answer my question if the parcel shelf has to be covered like emts said if there us fuel system is in the boot if the speaker holes etc need to be covered to create the barrier to meet the rules not to just fall into a category
I had to cover my speaker holes, I'm on a standard fuel system....damn MSCA.
If you have something other than the standard fuel system in the back I would say you will need the rear parcel sealed up.
With the standard fuel system you will get away without it most of the time.
Though mine is 'sealed' with some rubber sheeting....so...bah.
Stripped interior means you run in our mod class, but I would imagine you are running r-comp tires anyway.
Guest
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
