From CAMS sched B
save for 1st Category automobiles, be fitted with a bulkhead constructed from a flame- and liquid-proof
material. If the material is clear it shall be a minimum of 6mm thick. This bulkhead shall effectively seal the
cockpit from the fuel tank or re-fuelling system;
  • Replies 92
Cheers guys
I know the cams rules hence why I ask for the sau class is the cams rulings apply.
Yeah the old girl has r comp rubber on it so it really wasn't a matter of class more that if I turn up to the track with the parcel shelf uncovered and got the surge tank and fuel pump in the boot will have to run around and try seal it up.
Next thing is trying to cover it up without adding to much weight
Cheers guys
SAU Classes have nothing to do with the actual supp regs of the event. :)
Yeah I was thinking that might have to take a trip to me laser cutter mate and see what he has.
Yes ash I was wanting to know what the sup regs the sau championship follows in regards to sealing off the boot.
motorsport results updated:
http://www.sauvic.com.au/motorsport/2011_ClubChampionship.xls
after last weekend updated the lap records as well.
(ignore the date for Jack's PI sprint was this weekend, missed that on this update, is fixed in template for next one)
http://www.sauvic.com.au/lap_records
while we are on the subject of lap records... :thumbsup:
re the pre '89 times
i ran a 60.77 at hh in round 1, and a 1:12.5 at calder in round 2
not sure if any other members driving old bangers have ran quicker than these though.....?
  • 4 weeks later...
and results updated.
and it's going to be a close run for a few of the classes.
mod GTR
1 point diff
std GTR
8 points
Mod RWD 3 points
WRC class
even
Std RWD.
20 points...doh
and 3 points separating 2nd -4th outright
  • 4 weeks later...
ok...so last update till the end of the year..
after this round you need to come to the dec meeting to find the end results!
  • 3 weeks later...
Guest
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
