I know what they are for......they modify the pinion angle....but how exactly are they constructed, and where exactly do they go? cos owning a 77 model line, im guesing u cant buy em, so ill have to make em.........and i dont see the point in buying r33 ones just to use as a template....but i will if i have to.......i want to go side ways
https://www.sau.com.au/forums/topic/35097-pineapples-not-the-fruity-kind/
Don't you mean DONUTS, the type JMS sell that are yellow in colour.
The things I know of are mounted above the rear crossmember, to help eliminate the twist/flex of the crossmember and diff.
I have an R30 and I went to NOLTEC at Thornleigh NSW and got new rear crossmember & diff support bushes made from URETHANE.
Cost me about $400.00 for 4 bushes, but they work great, makes the rear end very firm. :ghost:
  • 4 weeks later...
You mean the whiteline KCA349 Rear Subframe Align and lock kit.
this kit has several different height rings and mixing/matching these can give the desired result of standard bushes, all round performance, maximum traction and drift, this kit however only come available for the s13-14, r32-33 and 300zx.
i am sure whiteline would make a similar kit, and as ghostrider said he got some custom made, and they are the same rear end(s)
  • 3 weeks later...
yeah pineapples, the original name until some aussies at whiteline decided to nename them subframe alignment kits.
there are two pinion angle options; under subrame at front and above at rear will loosen rear, above at the front and below at the rear will give more traction (this is the desired setting for drift and circuit.)
theere are a few places which can make them up her in adelaide for under half the $400 i saw someone post.
there other even better alternatives which perform better and cost less, spun steel. if you have access to a lathe spin them up. they give way more stability under high load and eliminate tramp, only downside is the transmit more NVH. i use a combination of both.
Cheers...this is the info i was after......much appreciated
also...roughly how thick are they?
18mm initial, 15mm installed.
front x4
70mm total diam outer
39mm inner hole diam
rear x2
80mm total diam outer
your skyline looks crazy, big fan. what V8 you running or transplanting. used to do some similar things earlier on. big hp 253 in 85 rodeo to tow ski boat, too much power not enough traction for a towey so replaced with stock 253. engine then graced a mark two cortina then finally ended up in my 12sec brougham which i stupidly traded on a soarer 3 yrs back.
    • Yeap, legal modifications are limited  We have rules and regulations on what you can do legally This is for NSW, other states have different governing bodies  https://www.nsw.gov.au/driving-boating-and-transport/vehicle-registration/how-to-register/registering-a-used-or-secondhand-vehicle/modified-and-non-standard-vehicles https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf Lots of people just roll the dice though and just hope they don't get picked up,  as the police and RMS occasionally run roadside inspections, getting "defected" for not complying can be a painful and expensive experience
    • Out of curiosity, I believe the title of "Engineer" is not protected in Australia like it is over here. I'm curious, does Australia actually have professional engineers do vehicle inspections?  If so, Jesus Christ what in the f**k.
    • When it’s broken I take one of my other r33s out its a little more reliable
    • I think a 60-90 mins drive is worth it, if the mechanic is good and has experience.  that’s what I’ve heard about CMS, so I’ll let you know how I go after Monday
    • lol I know!! I’m actually staying over at a mate’s place in SE the night before.  not because I don’t like the long drive. I just don’t want to drive from West to Seaford around 8am on a Monday 😂 traffic would be wild.    The Skyline actually does the West to SE trip without issues. My family is on that side.
