I know what they are for......they modify the pinion angle....but how exactly are they constructed, and where exactly do they go? cos owning a 77 model line, im guesing u cant buy em, so ill have to make em.........and i dont see the point in buying r33 ones just to use as a template....but i will if i have to.......i want to go side ways
https://www.sau.com.au/forums/topic/35097-pineapples-not-the-fruity-kind/
Don't you mean DONUTS, the type JMS sell that are yellow in colour.
The things I know of are mounted above the rear crossmember, to help eliminate the twist/flex of the crossmember and diff.
I have an R30 and I went to NOLTEC at Thornleigh NSW and got new rear crossmember & diff support bushes made from URETHANE.
Cost me about $400.00 for 4 bushes, but they work great, makes the rear end very firm. :ghost:
  • 4 weeks later...
You mean the whiteline KCA349 Rear Subframe Align and lock kit.
this kit has several different height rings and mixing/matching these can give the desired result of standard bushes, all round performance, maximum traction and drift, this kit however only come available for the s13-14, r32-33 and 300zx.
i am sure whiteline would make a similar kit, and as ghostrider said he got some custom made, and they are the same rear end(s)
  • 3 weeks later...
yeah pineapples, the original name until some aussies at whiteline decided to nename them subframe alignment kits.
there are two pinion angle options; under subrame at front and above at rear will loosen rear, above at the front and below at the rear will give more traction (this is the desired setting for drift and circuit.)
theere are a few places which can make them up her in adelaide for under half the $400 i saw someone post.
there other even better alternatives which perform better and cost less, spun steel. if you have access to a lathe spin them up. they give way more stability under high load and eliminate tramp, only downside is the transmit more NVH. i use a combination of both.
Cheers...this is the info i was after......much appreciated
also...roughly how thick are they?
18mm initial, 15mm installed.
front x4
70mm total diam outer
39mm inner hole diam
rear x2
80mm total diam outer
your skyline looks crazy, big fan. what V8 you running or transplanting. used to do some similar things earlier on. big hp 253 in 85 rodeo to tow ski boat, too much power not enough traction for a towey so replaced with stock 253. engine then graced a mark two cortina then finally ended up in my 12sec brougham which i stupidly traded on a soarer 3 yrs back.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
