Hi Guys,
I have a quick question about the EPA.
I have had two FULL EPA's in the past. One was in May and the other in September of last year. On both occasions I was pulled over by cops and defected on the spot and had the EPA notice(s) sent approx a month after the defects.
I then was told that if i get another EPA I would get a large fine. Does anybody know the cost of this fine and if this is true?
And if I was to receive a simple noise test notice in the mail would that still count towards the 3rd strike or does it need to be a full EPA for me to get this 'fine'?
I have checked the EPA sticky and read through quite a bit of it but couldn't find clarification on this.
Cheers
https://www.sau.com.au/forums/topic/351002-query-about-epa/
EPA notice is an EPA notice, even if it's just sound. If there is some sort of 3 strikes scheme then you can be sure you'll cop it. If they find you a large sum of money, it's because you're not "learning your lesson" and it's probably time to consider ditching the mods or the car?
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5632645
whether you think so or not... i can tell you as fact, there is
if you don't believe me, call the EPA yourselves :)
there are a number of users who have posted up of late that have been EPA'd with around a 500 fine.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633278
yeh the fine your talking about nismoid is the $600 one for exhaust noise been over which the people who copped that have been done at EPA random test sites etc, dont think you can get the find when you have been "dobbed in" so to speak as there is no proof your car is/was over the DB limit at that point in time.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633357
There is certainly a 3-strike type of thing as well.
I remember discussing this with Lou Raffa moons ago. He is the guy who does most of the inspections, you can contact him if you ring the EPA and ask to talk to someone about car related EPA notices etc.
I don’t agree or think it’s right – but they assume that if you keep getting reported, then you keep illegally modding the car after you get tested. Anyone who voted for Bracks should hang their head in shame.
  • Like 1
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633385
EPA & Fines = becoming more regular.
There can be a fine associated, rest assured it does exist, of that I am 100% certain.
Yep! I've only had one EPA for noise and they mentioned they weren't giving me a fine but the fine for a noise EPA notice is $599...
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633648
Thanks for the feedback and help guys :)
I guess my next question is - My 2 past EPA's were full ones (Noise/ Emissions + visual inspection under hood etc) so they weren't just noise ones. If I get done for another full EPA (not a noise one) will the fine be more severe then the $599 fine as mentioned in this thread?
Cheers
Brent
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5634217
YES you can get a '3rd strike fine'. My mate copped 3 EPAs (none for noise) and yes on the 3rd one he was going to have to pay a ~$600 fine if he was to clear it.
From what I remember the fine was not actually for not complying with emissions; it was a fine for putting stock stuff back on and trying to 'trick' the EPA upon inspection, despite the fact they had photo evidence of the highmount GT30 and External Gate not plumbed in :)
The car is no longer street registered.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5638637
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
