just bought a skyline r33 gtst a few days ago
want to know why its overheating
it started overheating today because the previous guy put techaloy 60 in, i filled it up with 90, the reservoir was at full mark, and when it overheated it went about 3-4cm above the full mark and the radiator had barely any coolant in it, n the coolant in the reservoir was boiling for about 10-15 mins...
so i did a coolant flush, put techaloy performance 100 in
but after about 30-45min drive it started overheating, the coolant in the reservoir was almost empty (was up to the full line before) but the radiator still had the right amount of coolant in it...
i cant figure out the problem, the cap seems alright, the thermo was opening because it was able to bleed the coolant
p.s. when it overheats it only ever got to the white line iust before it hit the hot mark (the white line is bout 5mm before the hot line), so it never hit hot
anyone got any ideas? much appreciated
Edited by caliibre
https://www.sau.com.au/forums/topic/351043-r33-gtst-overheating/
Im guessing you have checked for leaks?
Doesnt need a very big leak to start overheating, and if your loosing coolant to then that seems like the obvious cause
thing about the factory water temp gauge is as soon as it moves above where the operating temperature (which is just under half way) it means your water temp has hit 105 degrees. if its hit that a few times you've probably blown your head gasket.
a few ways to check if you've done this is to check for the following;
- milky substance in your radiator or oil cap (if its cracked through an oil galley)
- constant bubbles in your coolant (if its cracked through your combustion chamber)
- white smoke out of your exhaust (water going through your combustion chamber)
are you getting any of these?
yeah i thought i might have blown my head gasket but
-dont have any milky substance in radiator or oil cap (though when i pumped the old coolant out of the reservoir towards the end it looked clear almost like water, kinda milky)
-dont see anything wrong with the bubbling side of coolant
-not sure about white smoke coming from exhaust
new radiator cap ay?
The first tip happened to my R33 GTR just last week and i have done the gasket maybe a cracked head. Mine has oil getting into the coolant . I noticed mine getting when it was to late blew a big hole in radiator hose. Hope yours hasn't done the same thing i am up for big $$$ to fix it.
possibly try a new cap and see if that makes a difference (make sure you get the same pressure cap).
possible causes of overheating are:
dodgy cap
dodgy thermostat
leak in the system (including blown head gasket)
dodgy water pump
blocked radiator (which a flush will do nothing to help)
shagged clutch fan (although driving at highway speed it won't overheat)
had mine up to 119 on powerfc readout twice after the water pump leaked out the telltale hole and it was only half full. got it to a mates both times and fed water into it real slow. did another 50000km before rebuild due to damaged rings but head was ok. maybe i was just lucky but mine was well into the red so yours may be fine too
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
