Checked the fuses :D Have the checked the battery's voltage or tried a jump start? Dont assume the battery is ok just because everything else is working.
Do you hear the solenoid throwing the starter's gear at the flywheel? (ie a click)?
Ok i havent checked the fuses.. will do that..
I put the battery on my battery charger, and it litrally took like 5 mins to charge.. plus the car hasnt had a hard time starting prior.. and its a yellow top battery so yeah.. Havent jumped started it cos every one is at work lol
and theres no audible click that i can hear, all i hear is the fuel pump going as i turn the key over
Ok no click, so it sounds like no power to the starter. There must also be a solenoid for that starter - it should be under the bonnet - so it will need to be checked along with the fuses.
Yeah battery sounds good.
Sounds like the solenoid on top of the starter motor has jammed. In "old school" fashion, use a bigger hammer and give it a jolt, see if that frees it up. But first, chek that the starter wire hasn't disconnected from the solenoid.
